A cap is not the solution. It may seem to help, but it won't correct the cause. Using a cap to correct dimming light is an extremely common misuse.
What gauge is the wire you used? Amplifier model? What is the battery adapter?
Try using a wider wire for your ground, make sure is is properly grounded.
