Hi I have a 2005 CTS and I really like the 2013 CTS-V OEM rims!! And I was just wondering if they would fit on my CTS, since it doesn't really matter on the number of lugs the car has. Does anyone know?
Hi I have a 2005 cts and I really like the 2013 cts v eom rims!!
I don't know where you got that picture, but that's not a 2013 CTS-V; it's not even a real car. It appears to be a coupe based on the '14+ CTS.
How does the number of lugs not matter for wheel fitment?And I was just wondering if they would fit on my cts, since it doesn't really matter on the number of lugs the car has.
I got that picture of Google and it was the first picture I saw with the rims I like. I do not know what I meant about the lugsI don't know where you got that picture, but that's not a 2013 CTS-V; it's not even a real car. It appears to be a coupe based on the '14+ CTS.
How does the number of lugs not matter for wheel fitment?![]()
I wouldnt get those but that is me i prefer a 20. The cts honestly doesnt handle bad on a 20, ive got a really stiff suspension though i cringe on every pothole but in all honesty if you get some decent wheels and tires you will not have anything to worry about. I need a staggard pair for the back in the summer im gonna squeeze a 20x10 maybe 275-285 in back. I got 245 35s on all 4s, which is close to what stock gen1 v had except 19s 245 40 and i ****ing smoke tires. But i still got WAAYYY better grip than stock 225s cause i have a 2004 sport lux that had the 17in chrome those are gone though.I got that picture of Google and it was the first picture I saw with the rims I like. I do not know what I meant about the lugs
But by the way, do you guys know if the 05 cts, has tire sensors?
Close. V1s had 245/45-18s from the factory.I got 245 35s on all 4s, which is close to what stock gen1 v had except 19s 245 40
It might have been better to say, "My '04 doesn't, but I don't know if the later model years had them," rather than starting your response with a definite, "No, they don't have TPMS sensors." In fact, the later models do have optional TPMS - option code UJ6, which I don't think was available until '06.Btw no the 2004-07 cts doesnt have tire sensors at least my 04 sport lux doesnt idk if maybe there is a chance if you have the newer gauge cluster cause they changed it in 05-06 ctsBut by the way, do you guys know if the 05 cts, has tire sensors?
TPMS wasn't available unless your car was manufactures on and after Oct. 2006. Thats when the government passed that law requiring manufactures to include TMPS sensors on all vehicles in the US.It might have been better to say, "My '04 doesn't, but I don't know if the later model years had them," rather than starting your response with a definite, "No, they don't have TPMS sensors." In fact, the later models do have optional TPMS - option code UJ6, which I don't think was available until '06.
It's a little misleading. I had tpms on my 04 srx. But as you said. Cars went required since late 06. Doesn't mean they didn't have them before thenTPMS wasn't available unless your car was manufactures on and after Oct. 2006. Thats when the government passed that law requiring manufactures to include TMPS sensors on all vehicles in the US.
- TPMS was available on cars, including the CTS platform, before the government mandated it. My 2005 CTS-V has it as standard equipment, for instance.TPMS wasn't available unless your car was manufactures on and after Oct. 2006. Thats when the government passed that law requiring manufactures to include TMPS sensors on all vehicles in the US.
As josney said, that's the plug for the ABS wheel speed sensor coming out of the hub at that corner of the car. With that unplugged you should have an ABS light on at all times and the car should give you a "Service Antilock Brake System" and/or "Service Stability Control System" message when you turn it on. Do you have those indications?I was behind the wheel and I found that i haven't looked into the other side, which is something I will do today after work, but what is that? I know something should be connected right there, but I haven't found anything online, maybe you guys know something about it? Sensor?
Yes I do have the light on! Woow I though I would never find the problem, and would have to pay big bucks. I do have the abs light on, and what is the sensor called?As josney said, that's the plug for the ABS wheel speed sensor coming out of the hub at that corner of the car. With that unplugged you should have an ABS light on at all times and the car should give you a "Service Antilock Brake System" and/or "Service Stability Control System" message when you turn it on. Do you have those indications?
The sensor is the wheel speed sensor, and on these cars it is part of the wheel bearing / hub assembly. The sensor may be fine; you won't know until you plug it in. The sensor should be plugged into a wiring harness that runs alongside the parking brake cable. I don't have any pics showing where it plugs in, but here you can see the parking brake cable running diagonally across the picture, and the wiring harness (with the ribbed plastic sheathing) clipped to it.I do have the abs light on, and what is the sensor called?
I actually took the wheel off and found the sensor unplugged. Plugged it in and the abs sensor went off, I guess the last mechanic I went to didn't so I will come back! I also replaced the sway bar, which was why I took the wheel off! Thank you guys!! You guys are the best!! Appreciate it!!The sensor is the wheel speed sensor, and on these cars it is part of the wheel bearing / hub assembly. The sensor may be fine; you won't know until you plug it in. The sensor should be plugged into a wiring harness that runs alongside the parking brake cable. I don't have any pics showing where it plugs in, but here you can see the parking brake cable running diagonally across the picture, and the wiring harness (with the ribbed plastic sheathing) clipped to it.
If that harness isn't there, you have a bigger problem. If it is there, plug in the sensor and see if you get the ABS light to clear. If it doesn't clear, then see if you can get the code pulled (to verify it is just that one sensor that is bad), and then you'll have to replace that rear hub / wheel bearing assembly.
i hate em lol. Im glad my 2004 doesnt have that shit it is pointless and only for peoplewho dont look at their tires enough to even see a nail in it so what is the point.......TPMS wasn't available unless your car was manufactures on and after Oct. 2006. Thats when the government passed that law requiring manufactures to include TMPS sensors on all vehicles in the US.
