2000 Seville SLS
2002 Cadillac Deville head studs repair.
How deep do I dare extend the head bolt holes in the block?
The 2005 Northstars have longer head bolts and deeper holes.
You do NOT deepen the holes. The NorthstarPerformance head studs are made to the correct length for the model year of engine repair.
Hole depth is the reason that the stud install kits come with drills and drill stops for proper depth setting.
Late 2004 or 2005 blocks are a different casting. Apples and oranges from 2000 - 2004.
2002 Eldorado Biarritz
Do not drill deeper. There really isn't much extra material there. I've taken depth measurements and I don't remember all the numbers but I remember there was little enough extra material at the factory depth that I wouldn't even consider trying to go any deeper.
2000 Seville SLS
You're assuming I'm using someone's kit.
I'm asking how deep can I drill before I run into coolant jacket or other issues.
This is probably the answer I was looking for.
I'll say it again: You do not drill the cylinder block head bolt holes deeper than stock for your particular block. Plain enough ???
