1 - 2 of 2 Posts
Hello! I opened a can of worms. I replaced the starter on my 04 SRX. In the valley was a wiring harness that had melted and shorted out. I found this out after putting it all back together and had reduced engine power warning. So I removed it, and rebuilt it. I am certain I didn't cross any wires because I replaced them one at a time. But I may have the plugs confused. Is there any way to determine which plug goes to which cam sensor? I am getting codes P0011 P0014 P0021 P0300
I had replaced all 4 cam sensors about 30k miles ago, but two plugs are now full of oil. I wasn't having this issues before opening said can of worms.. so I assume the sensors are working properly, and my wiring is backwards. Is there anyway to determine which wire goes where, or any way to test the wires.
She's running a little rough, but I have to use it to get back and forth until the weekend. Should/can I just unplug the cam sensors for now?
At either Autozone or Advance you can register your car (free) and then in their maintenance section find all the wiring schematics for it. Start there.
1 - 2 of 2 Posts
