1997 ETC
I have a 1997 ETC that I needed to put new widow motors in. Now the window doesn’t automatically go down all the way. Is there a way to re-calibrate the windows after replacing a motor so you can do the one touch and I will go from top to bottom. Thank you
Wheel Tire Car Vehicle Motor vehicle
2010 DTS
There is a way to reset that feature, but I forget exactly how. Maybe someone else will remember the procedure. In the meantime, try pressing the down button and hold it or maybe press it several times.
Premium Member
99 Seville STS
Check the Vehicle Programming and Personalization Features in the owners manual
2011 STS Luxury
Programming the Power Windows
If the battery on your vehicle has been recharged,
disconnected, or is not working, each window must be
reprogrammed for the express-up feature to work.
To program each window:
1. With the ignition on or in ACC/ACCESSORY,
or while RAP is active, close all doors.
2. Press and hold the power window switch until the
window has fully opened.
3. Continue holding the switch for approximately
two seconds.
4. Pull up the power window switch until the window
is fully closed.
Repeat the process for all windows.
Express Window Anti-Pinch Feature
