As far as volume, that will depend on ported or sealed enclosures. Sealed can be made smaller and tightens up the bass response. The easiest way is to find the documentation online for the speakers in question. They will have recommended sizes already as well as recommended sizes and layout. I am in the process of building an enclosure right now. I have a little less room where you are looking to place them, so I built an enclosure to lift the subs off the trunk floor a little bit (access to spare) while acting as an amp rack and replacement for the trim panel in back.
Anyway, I have 2 Rockford 12" subs for the same type of setup. Each one shows a sealed 1 cu. ft. volume in my particular application, but the range goes as low as 0.7 cu. ft. and as high as 1.8 cu. ft. The difference in sizes will move the response curve slightly, but the smaller size provides for quicker/more accurate response. The "optimum" sealed enclosure is about 1.0 cu. ft., which I'm just under on.
