Status
Not open for further replies.
1 - 1 of 1 Posts
· Premium Member
"A" Service - 3k $59.95 (price in New York) - Every 3000 miles
- Change engine oil, lube and filter (additional charge for Northstar)
- Reset oil life indicator
- Lubricate chassis, rubber bushings and hinges
- Inspect air filter
- Check tire inflation
- Visual inspection of tire wear
- Visual inspection of wheel alignment
- Check all instruments, accessories and lights
- Check and fill all fluid levels
"B" Service - 6k $109.95 (price in New York) - Every 6000 - 21000 - 36000 - 51000 - 66000 - 81000 miles
- Rotate tires - computerized state of the art vibration system
- Inspect front suspension and check wheel alignment
- Lubricate and inspect front suspension, drive line, steering, hinges, cable guides and contact points (if applicable)
- Inspect front disc brake system
- Inspect rear brake system
- Inspect drive belts, hoses, cables, lights, horn, filters, tires and fluid levels
- Inspect exhaust system and heat shields for leaks, damage or loose parts
- Inspect throttle linkage
- Torque carburetor or throttle body mounting bolts (6000 miles only)
- Bravada rear axle service, drain and flush rear axle and refill fluid (Add $99.95 (price in New York))
"C" Service - 15k $329.95 (price in New York) - Every 15000 - 45000 - 75000 - 105000 miles
- Replace air filter, fuel filter and PCV
- Check belts and hoses
- Clean, inspect front disc brake system
- Clean, inspect rear brake system
- Inspect parking brake for damage and operation (adjust if needed)
- Rotate tires and balance - computerized state of the art vibration system
- Service automatic transmission/transaxle, replace necessary fluid and pan gasket, clean filter screen
- Service battery - Test battery charge and clean terminals
- Road test vehicle
- Wash and vacuum (Saturday only coupon offer**)
- Throttle body and fuel injection cleaning (Add $99.95 (price in New York))
- Timing belt replacement (Catera only - additional parts not included) (Add $289.95 (price in New York))
"D" Service - 30k $459.95 (price in New York) - Every 30000 - 60000 - 90000 - 120000 miles
- Change oil, lube and filter (additional charge for Northstar)
- Replace air cleaner and PCV, fuel filter
- Replace engine coolant, tighten hoses and connections, pressure test (2 gallons)
- Reset oil light indicator
- Lubricate body hinges and latches
- Service throttle body, remove carbon deposits, set idle to factory specifications, add fuel additive
- Tire rotation and balance - computerized state of the art vibration system
- Clean, inspect and adjust rear brake system
- Check engine timing
- Inspect EGR system
- Inspect fuel tank cap and lines
- Road test vehicle
Additional Maintenance
- Replace fuel filter $49.95
- Service battery terminals, check alternator output, lead test battery $39.95
- Electronic balance, 4 wheels (includes tire rotation) $69.95
- Align front suspension $89.95
- Align front and rear suspension (computerized state of the art system) $99.95
- Air conditioning service (leak test and add one pound of refrigerant)(extra refrigerant at additional charge) $129.95
- Drain and refill antifreeze $89.95
- Flush and clean fuel injectors $99.95
- Service automatic transmission/transaxle (replace necessary fluid and pan gasket, clean filter screen)(additional charge for Northstar) $99.95
- Replace front brake pads (resurfacing of rotors not included) $169.95 / additional charge to resurface rotors $75.00 / Extra charge for trucks and 4 wheel drive vehicles and other various types of vehicles; see your advisor
- Replace rear brake shoes (resurfacing of rotors not included) $169.95 / additional charge to resurface rotors $75.00 / Extra charge for trucks and 4 wheel drive vehicles and other various types of vehicles; see your advisor
- Emissions service - includes air filter, PCV filter and fuel filter $99.95
- Vehicle check for road trip (includes chassis lube, oil and filter change, plus 21 point safety check, tires and wheels, brake system, light system and signals, steering, shocks, front and rear suspension, fuel and exhaust systems, road test vehicle $88.95
- Complete alarm system, Lo Jack and remote starters (see your service advisor)
Prices do not include sales tax or disposal fee, wheel weights or liquid additives. Prices are subject to change without notice. These prices cannot be combined with any other advertised specials.
* Some pricing, services and offers may be different or unavailable in your area
**Offer may not be available in your area
1 - 1 of 1 Posts
Status
