1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
Hi all,
This is a loooooooong shot but here goes.....
I'm trying to figure out why my heated seats in my DTS don't work. First it's a flood car. The front seats are original (and thus have the flooded heat elements in them) as is the rear seat bottom. The rear seat back is out of a collision total. The only heat that works is in the rear seat back. Since the rear seat back is the only part that was not under water I assumed that the problem must be with the elements.
I ordered up complete sets of elements for the front seats. I installed the LH cushion elements yesterday. They don't work.
I've run through the diagnostics and I'm pretty perplexed at this point. The resistance of the new elements is obviously good - under 6 ohms. The rest are bad - 30+ ohms. I figured at least the new seat cushion elements would work, but no.
So I got looking at how it works. The module senses resistance to know how hot to make the seat. High resistance = hot. Thus, if the module senses high resistance it will shut off the power to the heat. It appears as if the seat back and seat cushion elements are sensed and controlled separately. Even so, I thought maybe the baked seat back element could affect the seat cushion, so I unplugged it (unplugged = no resistance). Still doesn't work.
I'm getting juice at the module. When I put a voltmeter on the heat element supply I can see a blip of 12+ volts from the switch and then it goes away. From what I understand, the module counts the 12V pulses to know how much heat you want (low, medium or high). Once you get that initial 12V, the module will apply enough voltage to heat up the element based on the resistance (i.e., how hot it is already). When I test the seat back circuit on a working rear module, I can see the module ratchet down the voltage on the high-med-lo settings.
So, I moved a working rear module up to the front and it didn't work. Now, in the rear I only have the seat BACK working. When I moved that module up front, I got nothing out of it but I know the front seat BACK is toast. What's weird is that when I put the rear module back where it belonged, it didn't work at first. I hooked up a voltmeter to the input on the known working rear heat element and I was getting nothing from the module (except for that split-second of 12+ voltage). After a few minutes, however, it began working again.
So now I'm not sure where to go. Since the backs and cushions are monitored and regulated separately, I'm wondering if the flooded elements have baked their respective parts of the modules: cushion/back in the front, and cushion in the rear. Thus, when I move a rear module up front to try to get the cushion to work it won't.
I'm baffled at this point. It can't be a short to ground in all 4 seating positions, which is the only option the diagnostic procedure gives me.
Should I invest in a new module to test with?
TIA,
Jim
TIA,
Jim
