DTS has 73,000 miles no accidents, in overall good condition. Issue started as intermittent, would trigger ABS/TC dash lights only after hard acceleration from stop. Scanner confirmed, what I was feeling, left front ABS. Did some driving tests with scanner, decided to replace wheel bearing/ sensor. After bearing replacement dash lights and code are hard set, on all the time. I checked wheel sensor continuity and AC voltage at sensor, both within guidelines. I then checked continuity from EBCM connector to wheel sensor, no resistance, even when pulling and twisting wires. Next test was for zero volts,( key on, using EBCM ground terminal) checking both wires from EBCM connector, received around 4 volts on each wire. Scanner tells me to repair short to voltage in sensor signal circuit or the low reference circuit . So, without dropping engine to gain access to remove wires from plastic looms how do I find shorted wires. I also measured for infinity ohms of resistance between the wheel speed sensor signal or the low reference circuit and ground at EBCM connector, tested good. Thanks in advance.
