Almost pulled the trigger on those, but didn't want to buy new rotors right now. Just resurfaced mine since thickness was 33.5mm. Figured if I was going to get super aggressive Pads, new rotors were a must. I just went with stock ones by Brembo. Race season will be much shorter this year, probably try those R4-S next year.Has anyone tried the Porterfield R4-S pads Renick Perfomance has on his website?
Maybe I should also go with oem, i have 58xxx miles now and i doubt the previous owners replaced the rotors if the brakes need to now. They ones you went with were the ones in this thread?Almost pulled the trigger on those, but didn't want to buy new rotors right now. Just resurfaced mine since thickness was 33.5mm. Figured if I was going to get super aggressive Pads, new rotors were a must. I just went with stock ones by Brembo. Race season will be much shorter this year, probably try those R4-S next year.
I do not recommend Porterfield R4-S pads for track use. I tried them once and they only lasted 1.5 days at Laguna Seca and I was forced to do a change back to my old Ferodo pads in the paddock, causing me to miss a run session (I'm slow). In the photos, the R4-S pads are in the middle. I then tried Hawk HP+ (new pads at bottom of picture) which feel much like the OEM pads. You can see how thin the R4-S pads got in less than a weekend. My original Ferodo pads at the top of the photo lasted 7 1/2 track days and weren't as worn as the R4-S pads.Almost pulled the trigger on those, but didn't want to buy new rotors right now. Just resurfaced mine since thickness was 33.5mm. Figured if I was going to get super aggressive Pads, new rotors were a must. I just went with stock ones by Brembo. Race season will be much shorter this year, probably try those R4-S next year.
Have you done a 150mph to 90mph semi hard brake? In my experience, they heated up quick & started to vibrate. Also don't like how soft they are when cold. Z26 do a great job 90% of the time & are low dust. I'm going back to stock, seem to have more bite especially when cold, but do have a ton of brake dust.....from the pads not rotor....LOLI'm running Power Stop Z26s on my CTS-V, they're great for street driving - plenty of stopping power, low dust, and inexpensive. The past couple years I've also run the Power Stop Track Day pads on the CTS-V, front and rear. Again, I found they work great, comparable to the Hawks and Carbotechs I've run previously, and the price is absolutely unbeatable.
Good idea! Powerstop is an entry level daily driver brake pad/rotor. These pads are scary bad. The reason why the pads are so soft is because they use low end materials to keep the brake pad quiet. Your life is not worth saving a few bucks on cheap brake pads.Have you done a 150mph to 90mph semi hard brake? In my experience, they heated up quick & started to vibrate. Also don't like how soft they are when cold. Z26 do a great job 90% of the time & are low dust. I'm going back to stock, seem to have more bite especially when cold, but do have a ton of brake dust.....from the pads not rotor....LOL
I said they're great on the street, so no, I haven't tried to do a semi hard brake from 150mph.Have you done a 150mph to 90mph semi hard brake?
By "soft" do you mean you think they don't feel as grippy when they're cold? If so, then no, I haven't noticed that. I find the grip to be pretty uniform - they don't get grippier as they warm up like semi-metallics tend to do.Also don't like how soft they are when cold.
You mean ceramics.I said they're great on the street, so no, I haven't tried to do a semi hard brake from 150mph.If that's what your street driving entails, then clearly a ceramic pad is not the right choice for you.
These work great on the street. I've done some aggressive stops and never had any issues as long as you bed them in properly.Have you done a 150mph to 90mph semi hard brake? In my experience, they heated up quick & started to vibrate. Also don't like how soft they are when cold. Z26 do a great job 90% of the time & are low dust. I'm going back to stock, seem to have more bite especially when cold, but do have a ton of brake dust.....from the pads not rotor....LOL
I've heard they are excellent, but at the price point they should be.Has anyone tried the Porterfield R4-S pads Renick Perfomance has on his website?
This was a fun page to look thru. Do you use the OEM "brembo" rotors with these ST-43 pads as a Track Set? Seems like a great way to go... as with many auto-applications, you can't have Awesome Track & Awesome Street with just 1 setup.My current track set is Raybestos ST-43. Also very good for the track, slightly less aggressive. Wear has been good so far. I have a separate set of rotors for the track brakes so I don't have to mess with re-bedding pads when I swap back and forth.
