I will only say this one more time -
you ran the BLOCK TEST - AND FAILED -
I wouldn't invest a single penny into ANYTHING -
until you decide whether or not you are going to fix the head gaskets -
good luck -
Again, basscat, I appreciate your knowledge and guidance. To be perfectly honest: if it's a head gasket problem, then no, I won't be investing any more $$$ into this Eldorado. I'll sell it as-is, or park it in my backyard corral for future use, then and go pick up the car I really want (and can work on with my tool box, without needing anything electronic or handheld), a 5th generation ('65-'68) Cadillac with a 472.
I've had my fun with this car, but I'm not sentimental...if it's going to give me this much trouble, I don't have the time, desire or money to keep investing into it...I'm an old-school, non-electronics V-8 mechanic at heart, and that's where my loyalties lie.
But, all that above being said, I'm still intrigued as far as solving the problems I can with this car, before I have to sell/retire it...hence this update.
Today, I rented the noid set, and found out that all my injectors are getting fire perfectly, so the PCM and/or signal issue is out. I also pulled both non-firing injector plugs (since they aren't working, anyway) and drove it down to O'Reilly's to have them run the code scanner again...same as last time, "random misfire detected".
I picked up a set of 8 N* injectors off a guy on the Bay for 20 bucks, and some new o-rings....I'm going to replace the two questionable ones this week, and see what happens.
I also found 6 N* coil packs at the local junk yard, at 30 bucks each; I'm going to swap out the injectors first, and then if that doesn't work, I'll buy 2 of the coil packs and replace mine, and see if that works...all said and done, I'll only be into it a further 90 bucks or so, and that will satisfy my curiosity.
Rob
