Re: Rattling/thumping on floorpan, Check Engine (SES) light
Not ignoring basscat's post about a possible head gasket issue, as I appreciate his valued insight, but I'm incredibly hard-headed in accepting that diagnosis; until I have ruled out all the issues that I'm questioning at this time, I'm gonna keep stabbing at possible culprits. Maybe I'm dumb and blind and fooling myself, but I gotta try. :yup:
That being said, I went ahead and swapped out the coils to see if the No. 5 cylinder misfire would 'jump' to No. 4; I had also cleared the PCM codes, so now when I take it down to O'Reilly's for another test, they get the generic P0300 "random misfire" code I do. The guy tells me I have to tun it for a few cycles to 'lock' in a specific cylinder misfire...meh...I don't know enough about how that works, so I guess I'll run it a bit longer and take it back down there later this week, to see if we can pinpoint it again. SES light is still flashing. :annoyed:
I
have heeded basscat's advice about forgoing the pressure tests at this time, though; I want to run some new stuff I discovered by you first.
Cooling system pressure: I notice I don't have any. I could run this car for 200 miles, take the cap off, and there's NO pressure release, no boiling over, nothing...although the reservoir is usually about 3 quarts low. I'm assuming that if I have a bad cap, the system could be venting my fluid at highway speeds, and I would never know...is this correct?
Either way and to be safe, today I bought a new cap, put it on and drove the 1 mile to home, and when I checked it, I got a "pop" of air pressure release when I turned it. Hopefully the problem of fluid loss is solved; time will tell.
Fuel injection system: Today I ran the car, and got this horrific new smell of emissions/fuel smell, plus the really worse-than-usual, sputtering pulpwood truck, misfire condition. Last week while driving it to work, I could feel the car "surge" under power at highway speed, on-and-off, like it was trying to smooth out, but couldn't. I checked the FPR again for leakage, but found none. SES light is still flashing.
Although I haven't rented the noid set yet (this weekend was my wife's birthday, so Saturday mechanic'n was OUT, lol :tisk
, I did decide this afternoon to try a shade-tree test on the injectors by trying the screwdriver-stethoscope sound test. Although I did get the rhythmic fast 'ticking' at each one, I decided to pull off each wire connector while the car was running to see if I could hear or feel a noticeable change...and lo-and-behold, I could, on cylinder No. 1 and No. 4.
When I pulled the other leads off and back on, I could hear and feel the engine change; when I pulled these two off,
and left them off, there was
no change. I plugged them in,
no change.
I guess my next move will be to rent the noid set, to see if the PCM pulse is getting to the injectors; if it is,
can I assume I have two faulty fuel injectors (I understand they cannot be cleaned)?
Rob
