I need to replace bulbs in the front end of my 2005 ctsv. She has ~130,000 miles & bone stock. I don't drive her much, as I'm away from home a lot. First one fog light went out, then the other one. Shortly after, one HID went out. Before they left, I was noticing a flickering; it was intermittent & I couldn't link it to rough roads, rpm, etc. I've read that the flickering could be due to a ballast going south. Is there an easy check on the ballast? Since it looks like I'll need to remove the fascia, I want to get it right. I also want to replace all the bulbs so I won't have to remove all this again. I would like to go with LEDs (except for the HIDs). Have any of you made this change? Where did you purchase them? Plug & play? Part #s-especially for the parking light? (the small bulb that blinks when you use the remote).
