1 - 13 of 13 Posts
97 Cadillac DeVille
Looking for an easier way.....The bolt that holds the idle pulley to engine has snapped or broke its a clean break straight down even with the engine block so I cant grasp it with anything I cant fit a drill down there. I cant get a Right angle drill in the area either. does anyone know how I can remove this bolt in such a tight space? Any help is greatly appreciated. Heres a pic if u can tell what I m talkin about <a href="http://photobucket.com" target="_blank"><img src="http://i130.photobucket.com/albums/p252/txpiedpiper/100_0481.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Ouch... I'm not exactly sure how bad your situation is. I have had some pretty nasty bolts shear off to the point that I couldn't slip a drill/easyout in. In that rare case, I've taken a spare bolt/nut, placed it up to the broken bolt and taken a very small MIG welder with a small gun to weld the spare bolt/nut to the broken bolt. Then you use a wrench to turn out the old bolt I've had to use a small mechanic's mirror to guide the MIG wire in. You have to be a pretty damn good welder, though to not weld your broken bolt to the inside of the thread.
Pretty extreme, and it may not work in your situation.
Sedan de Ville, CTS
Been 34 yrs since I did something like that. Then I broke the easy out too. That was on top of engine--thermostat.
There is a tech with 'will' as part of his name on avatar. He is good with advice. Some of the moderators are also good mechanics.
Post again in a day or two if no response. Might want to post in technical section too.
1992 Sedan DeVille
What I found that works decently:
Get a right angle micro die grinder. (A Dremmel tool), and a diamond straight bit for it. Drill a hole through the broken bolt. Now, get a LHT (Left hand thread) metal screw, self tapping works if you can fit some sort of driver drill in there, or just standard threads, and run that in there.
What happens is this: THe left hand thread screw will go down into the hole, and once it's fully in, continuing to turn it will get it to bite into the metal, and turn the fragmented bolt out. Just make SURE you use a metal screw, not a wood or sheet metal, and a LHT one.
97 Cadillac DeVille
Spent $300 to get the damn bolt out $300 to get a broken bolt out funnyWe gotta lift the engine to get to the bolt blah blah blah blah I spent two weeks trying every day after work whole saturday and sunday %$#@& #@*&@ countless left threaded drill bits if it aint one thing its another now I got a busted brake line replaced the line now I cant get the brakes back tight I done bled the brakes..How about I take it to my local 7-11 leave it running and take off running leave the problems to someone else but I cant I love my 97 deville my lil green piece of $&*%
'04 Base Deville, Light Platinum - blew HG & SOLD
How about I take it to my local 7-11 leave it running and take off running leave the problems to someone else...
well, you know how the law works.
If someone were to steal that car (that you left running) and kill someone with those bad brakes (which you knew about), you would be responsible. LOL!
2010 DTS
What do you mean by "I can get the brakes back tight"? Front or rear?
1997 Cadillac Deville
Say bro piedpiper, where did you get the broken idle pulley bolt work done? Im from Dallas and have a 97 deville with the same exact problem. People been trying to charge me like 700+ to do this.
you do know this thread is 4 1/2 years old - don't you?
1 - 13 of 13 Posts
