1999 DeVille
My 99 has 70k and as far as I know the pads are original. The brake peddle pulsates when applied. Is it the rotors? Its my understanding that I would get a warning on the console if the pads were low. Also, my oil indicator icon flashes intermittent when at stop lights, oil level is fine. Thanks in advance for the info.
2010 DTS
Your car has electronic wear indicators and you will indeed get a warning on the dash when they are low. The pulsation you feel in uneven brake pad deposits on the rotors. A light skim cut to clean them up will solve that. As for the oil light, it sounds like a bad pressure switch. Use only A/C Delco if you replace it.
