2006 Cadillac CTS 3.6 liter
I went to my mechanic for a different issue and he hooked my car to a fancy computer and it says my abs module is going out. My brakes are very strong and only stutter while at low speeds. My rotor and pads seem good.
Does a module make sense? And how can I fix it and where is it? Possible price?
06 CTS Sport/Luxury package
Check to see if either of your brake calipers stick.
One of mine has been for a while. My problem was when I slowed done to make s turn. I would steer to the direction that I wanted to go. But just before s complete stop, the ABS would kick in because it thought I was sliding. When in fact my caliper was sticking.
Lift up the front and spin the wheels. Normally both should spin with little effort.
KOT
CTS 3.6L 2005 80,000 Miles
got some advice a while back which i'll pass on to you. whenever you have any brake related issues always do a fluid replacement and bleed. suction the old fuel from the reservoir get all the soot out then replace with new fluid. then do a bleed. 9-10 be it sticking calipers, or abs issues this will help. You would be surprised how much soot is in the reservoir. This should actually be routine maintenance every 30k miles.
