Brake change now big problems
1119 Views 5 Replies 5 Participants Last post by  txbest1980
Alright I searched and found a few posts however, im hoping maybe you guys can help me narrow it down by finding out what happened. I paid an outrageous amount to have my front brakes changed a few weeks ago (I had no choice). Not wanting to be in that situation again i ordered new pads and rotors from R1 Concepts.
We put them on last night. Not realizing that the guy who parked the car and put the wheel chocks down also set the parking break. We beat on our stuck rotor for a little bit with a 16oz rubber mallet before it clicked that something was holding it on....(NY winters, having to beat a rotor off is very common)
The rest of the change went very smoothly.
I headed up the road and bedded the brakes. A ride up the mountain and then down to cool em off. As soon as i turned around, My ABS, TC OFF, Service Stability System, and Service Brake Assist came on. I got back and the brakes were hot as hell, which is normal after putting them through that. So i figured that it was a fluke. Reset the car, no problems driving 20m to my apt. Drove 30m to work today, no problem. However, as soon as i left work, they all came back on. Reset them, and it lasted a few miles. Then came back on. I drove it the 300m back to my house with no problems but the lights. Theres no squealing, no vibrations, brake pedal is firm....Im taking it to the garage monday morning but id like to give them as much help as possible. I will not take it to the dealership as i have problems with the only one in that area.
What could i have done? If your looking at the rear right rotor, theres a line coming in on the upper left side that looks like a sensor. Is it possible my problem is that? It may have gotten nudged once or twice when hitting the rotor.
Will the codes actually tell them the exact sensor that is bad...
yup each wheel sensor will throw a different code, wiggle each connection and make sure they are secure. mine acts up like that in slushy weather. in the rain it's fine, when it's dry out it's fine, when it's cold and snow it's fine. but for some reason when it's slushy out mine will act up from time to time.
in your case the slushy means that water is getting into the connector then freezing and expanding, causing the issue.
rain means nothing will expand.
full on snow means that it is cold enough that there is not liquid water around.
i think this summer i'm gonna heat shrink the connections. unless somehow the water/slush is getting into the hub itself.
If the brakes feel good and are working properly I would try disconnecting the battery for about 15 minutes and then reconnecting and see if the car throws me any errors again. If it doesn't I wouldn't worry. If it does then I would take it from there.
