I just received the OEM rear brake pads (AC Delco 171-0882) and it didn't come with any bedding instructions so I found one here http://www.cadillacfaq.com/faq/answers/bedbrakes.html. The first process is easy enough to do on the freeway....
From a speed of about 60mph, gently apply the brakes to slow the car down to about 45mph, then accelerate back up to 60mph and repeat. Do this about four or five times to bring the brakes up to operating temperature. This prevents you from thermally shocking the rotors and pads in the next steps.
However, I am concerned with doing the 2nd process on the freeway. I was wondering if it's absolutely necessary to perform them?
Make a series of eight near-stops from 60 to about 10 mph. Do it HARD by pressing on the brakes firmly, just shy of locking the wheels or engaging ABS. At the end of each slowdown, immediately accelerate back to 60mph. DO NOT COME TO A COMPLETE STOP! (Note: With less aggressive street pads and/or stock brake calipers, you may need to do this fewer times. If your pedal gets soft or you feel the brakes going away, then you've done enough. Proceed to the next step.)
