2003 CTS
Hello all,
I have scoured every forum and the entire internet. A lot had asked, but no definite answers.
I am trying to figure out, in my 2003 Cadillac cts with a BOSE system, what the OHM ratings are on the front & rear doors and center dash speakers are.
I had read rumors that the rear are 4 ohms and the front doors and dash are 2 ohms. I have even tried looking for the amp specs.
The reason I am asking is because I want to change the speakers and keep the working bose amp. Thinking Kappa 2 ohms in the front and not sure what 2 ohms i can put in dash yet. I know 3.5" fits in the dash. Front doors 6 3/4"- 5 1/4" , rear 5 1/4". Once i get the ohm ratings it should be easy.
If no one has the answer i suppose I'll be disassembling and removing the speakers to read each speaker to get the ratings.
I would appreciate any help if this has been answered anywhere, or if not we can get it here for everyone.
2006 STS V8 1SF RWD
Every Bose speaker I've ever tested has measured in at 0.75 Ohms.
2003 CTS
wow, Guess I will lose a lot of volume with any speakers i try to replace them with then, unless i get uber involved and switch amps...meh
........ and if you switch amps or the head unit you have a slew of hoops to jump through - the sound system is part of the car's TheftLock, content security, and serial data bus systems.
Talk to the guys at Crutchfield.
2003 CTS
I already did switch the radio to a double din stereo and tapped into the input to the amp. I followed that write up someone had put up. I did keep all the functions, alarm, volume on the steering wheel and all the onboard computer functions. I didnt lose any functions at all. Everything is working fine. I just was looking to upgrade the speakers. The dash one sounds like it has ripped.
2007 CTS 2.7L
No offence, but I am doubting the .75ohm as NOMINAL resistance. Even the best high-end amps have a MAX low end resistance of .5 and that is for subwoofers and class D amplifier circuits. In addition, there is the impedance rise during actual use. But that is typically for subwoffers and not mids/highs.
You should be absolutely fine with 2-4 ohm speakers. I did infinity in mine (2ohm) and got better and louder sound.
2003 CTS
I think there used to be a write on this. I just couldn’t find it anymore. I think you are right on the 2 ohms. Most high end 4 channels seem to be stable down to 2. I appreciate all the inputs. At least I know now 2ohm all around it can handle
