Ok guys...
I've been down this road before, and found the right caps. It was a search, but DigiKey Corp offered the 820uf 16V caps I needed to finish replacing all my caps on the rear speakers of my STS. I replaced the other caps with tantalum caps to increase reliability. I just discovered that I have a burned out surface resistor on the back side of the circuit board. It is in the middle of two other surface resistors marked "A5". Does anyone have a contact at Bose or some other place that would have a schematic on this circuit board? Bose is a tight ass on the subject. The guys at http://www.carstereohelp.com just want my money for the whole thing. Anything else out there?
Thanks,
I have a Bose Gold circuit board that is dead, perhaps you could use a resistor from it. I'll send it to you no charge.
Jim
R&D Guy said:
Ok guys...
Thanks,
Jim
Hey Jim,
That would be great! Sorry about taking so long to get back to you...holidays and all. Let me pull my board again and see which ones I could use.
Thank you again,
Bert
Guys
I have a 92 deville with Bose Gold.
When I hit the power button, all I hear is loud hum that I can not even turn the volume down on.
Any ideas?
Guys
Any ideas?
I narrowed the noise down to the speaker in the front passenger door. No other speakers are making noise. I hope there is a wire touching that I can fix. Next step is getting the door panel off without breaking anything. I think there are screws under the lights on the armrest. I will try to find them...and update.
Turns out the speaker was OK. I changed the circuit board and it works fine now. Only thing left is my CD does not work. It shows "ER" when i try to playt one. I opened nad cleaned the EYE but no luck.
Anybody had this problem?
