1 - 10 of 10 Posts
12 CTS 3.6 Coupe Premium Black
I've struggled all morning trying to get audio to stream from my VZW Moto X, and TMob Note 4 to my 2012 CTS Premium w/NAV. Phones connect fine, send receive/calls is fine, but no music. I tried going around it and loaded music to a 32G USB drive. DL'ed everything to HDD, except for 2 long mixes(1.5hrs+). Not only can I not stream music directly from my phone, but large music files can't be read from the USB drive.
Next workaround was a BT/USB adapter that I have. The car won't recognize that device.
Last option is a cord from phone to AUX jack, and that is no option. Absolutely not!
Am I missing something?
Black Tesla Model 3, long range, AWD
Your phone connecting fine and being able to send/receive calls fine but not stream music is how your car works. The available Bluetooth isn't meant for streaming music, nor is it possible. It's only for phone calls.
CTS
I have an A2DP adapter. It's a bit clunky to use as is does not reconnect automatically. The sound quality is typical Bluetooth, adequate but not HiFi (well neither is the Bose system).
But I can now stream music, and mix in the voice from the Waze application at the same time.
Discussion Starter · #7 ·
I may try another adaptor. I typically use streaming services quite a bit.
As far as the USB/ large file issue I mentioned, it wasn't a file size issue at all. Poking around the forums I read mention of bit rate compatibilty. I coverted my 320kbps files to 128kbps and they were recognized, and rec'd to the HDD. A couple of those files were 2+ hour long mixes.
2013 Black Diamond CTS4 Premium Coupe (sold-09 CTS4 DI Black Raven/Ebony)
So the mix tape is out and the mix disc is in. :stirpot:
But don't throw away your old tapes...look at the comeback of the headphones! :yup:
99 Eldorado, 2012 CTS Coupe, '06 Deville
MPOW connects fine to my phone for streaming music, but the volume level and sound quality is degraded.
1 - 10 of 10 Posts
