I think I have an '83 Eldorado with the 4100 HT engine, with a blown head gasket or something worse.
I am getting tons of pressure in the cooling system - it blew one hose on me, leaks from spots like the thermostat housing, overheats very quickly ( 5 minutes or less of driving ) and the coolant tank is overflowing.
I have read the thread on "help ! did I blow it ?". Not sure if my case is the same.
I have no odd color to the engine oil, and no visible leaks on the engine itself as per cooling leaks. I had an 85 eldorado with a blown intake manifold gasket, and that was clearly leaking coolant on the top of the engine - no such example here.
I know the next step is to take the puppy apart, and look for blown gaskets in the intake and head gasket areas, but I am worried that I might spend a lot of time replacing gaskets when there could be other trouble with the block, such as it being warped or cracked. I suffered the pain of once fixing a blown head gasket to only find later that an aluminum block was cracked and needed replacement ( not a cadi - looong ugly story
Anyway - can anyone give me things to look for to help determine if I only need a head gasket, or something more in line with a whole new engine ??
I also could use advise on books / manuals for procedures on the proper method of replacing head gaskets, etc, on such a car. Not sure if the Chiltons in the auto parts store is the right buy, or if I should search on line for better books for instructions.
cheers !
cheers !
