Hello Folks
My blower motor hasnt worked since I bought this 87 Brougham. Im getting 12v to the motor but it doesnt turn. Are there any other checks to make before I pronounce it dead?
1980 FBC
The ground connection for the blower is made through the power module. Try grounding the case. It floats above ground in the fiberglass HVAC box. Use heavy test clips or wire as the current draw will cook a small wire in a few seconds. If the blower works with the case connected to ground then it's time to check the power module. Easiest way to test it is by substitution.
