Blinking check engine light 2004 SRX
33K views 562 replies 11 participants last post by  geocoy2
geocoy2
2004 SRX AWD V8
Joined Sep 18, 2021
  • 01-12-2023
My car will not start. When I try to start the car it does nothing. No clicking or anything. Initially it had blinking Check Engine Light. This is an indication there is a serious problem. I had AZ test my battery and it is good, and I have a new starter, so the problem is somewhere in the system. So I borrowed a Code Scanner from AutoZone and I am trying to read failure codes. I used the information from the code scanner, I got a code P0346-00, and it was telling me the Cam Sensors may have a problem. Well, the Cam Sensors had cracked connectors from a previous repair. So I replaced the connectors and the sensors, and the failure code went away. I also replaced the MAP (its and intake Air sensor) because the connector was also damaged and was seriously corroded with oil.
The first three pictures are the initial Failure codes I was working with.
When I try to start the car now, it still does nothing, no clicking, just nothing. The blinking Check Engine light is gone. But the ignition won't allow me to remove the key. So I have to use a tool to remove the key. I ran a scan tool a second time I will post that information in the next Reply below.
Anyone have any ideas?
#394 ·
Engine Harness Connector
1​
RD/BK​
342​
Battery Positive Voltage​
2​
PK/BK​
5290​
Ignition 1 Voltage (LY7)​
3​
PK/BK​
5294​
Ignition 1 Voltage​
4​
D-GN/WH​
459​
A/C Compressor Clutch Relay Control​
5​
D-GN​
59​
A/C Compressor Clutch Supply Voltage​
6​
PK​
39​
Ignition 1 Voltage​
7​
Not Used​
8​
PU​
6​
Starter Solenoid Crank Voltage​
9​
PK/BK​
5291​
Ignition 1 Voltage (LH2)​
10​
PK/BK​
5291​
Ignition 1 Voltage​
11​
PK​
239​
Ignition 1 Voltage​
12​
PK​
239​
Ignition 1 Voltage
13​
PK/BK​
5293​
Ignition 1 Voltage​
14​
Not Used​
15​
PK/BK​
5290​
16​
PK/BK​
5290​
17​
D-BU​
473​
High Speed Cooling Fan Relay Control​
18​
YE​
343​
Accessory Voltage​
19​
YE​
343​
Accessory Voltage
20​
Not Used
21​
D-GN​
335​
Low Speed Cooling Fan Relay Control
22​
PK/BK​
5292​
23​
PK/BK​
5292​
Ignition 1 Voltage
24
YE
447
Starter Relay Coil Control
25​
BN​
5069​
MAIN Relay Control
26​
RD/WH​
1440​
RD/WH​
1440​
appears pin 24 on connector 5 of that bunch should run back to the ecm
#396 ·
YES as I mentioned it is circuit 447, yellow
So one side of OHM meter to pin 24 of that ECM connector
and other probe to the connector in the fuse box that goes to the control ground of that relay would
pinpoint if the wire/pins are the fault or leaves the issue with the ECM
1​
RD/BK​
342​
2​
PK/BK​
5290​
3​
PK/BK​
5294​
Ignition 1 Voltage​
4​
D-GN/WH​
459​
5​
D-GN​
59​
6​
PK​
39​
Ignition 1 Voltage​
7​
Not Used​
8​
PU​
6​
9​
PK/BK​
5291​
10​
PK/BK​
5291​
Ignition 1 Voltage​
11​
PK​
239​
Ignition 1 Voltage​
12​
PK​
239​
Ignition 1 Voltage
13​
PK/BK​
5293​
Ignition 1 Voltage​
14​
Not Used​
15​
PK/BK​
5290​
16​
PK/BK​
5290​
17​
D-BU​
473​
18​
YE​
343​
Accessory Voltage​
19​
YE​
343​
Accessory Voltage
20​
Not Used
21​
D-GN​
335​
22​
PK/BK​
5292​
23​
PK/BK​
5292​
Ignition 1 Voltage
24
YE
447
25​
BN​
5069​
MAIN Relay Control
26​
RD/WH​
1440​
RD/WH​
1440​
#395 ·
The coil of relay draws little current so has to be the smaller yellow wires to trace down
There are 2 wiring loom bundles, check to see which one goes to the ECM
You already proved that using a jumper to take place of the relay's coil, it is NOT a 12 volts issue
While that is apart, I suggest spaying all the wiring pins with electronic cleaner
You should be able to use OHM meter, 1 probe to the connection of relay for control ground
and other probe on the backside as showing below the crimped connector on yellow wire to find which is
the ECM yellow control wire
That maps that relay connector and exactly which yellow wire, to then follow down to ECM to OHM out at that ECM pin and the yellow crimp connector at fuse box.
#397 ·
Do a Simple start test
Since the ECM is turning the relay coil on by a controlled ground to coil
And assume either the ECM is not doing that or the yellow wire is bad
Take a small gage wire, connect one end to a ground point
Take the other stripped in and push it into the female connector pin 86
Now put that relay back in and now the coil has the ground
Cannot make it any simpler than this
Try starting
#404 · (Edited)
By adding the new wire you are providing a ground, then try to start the car.
I can try that.
NEW EDIT
  • I was able to run a ground wire from the negative battery terminal directly to pin 86.
  • The result = Nothing. the Starter refused to even click.
  • Removed the wire and tried to jump it and I was successful starting the car
  • Have no idea why it would behave that way unless I burned out the Relay
#405 ·
1997_eldorado Team ZR-1
I borrowed the Code reader from Auto zone and it looks like all the old U codes are gone. But I got a new P0641 that points to bad wiring, so I looked at this video and it reminded me of some previous work.
I saw this video on Youtube and it reminded me of a few places where I have bad wiring. When I removed the plenum to replace the starter there were several harness that were oil saturated and had broken wiring. Im gonna replace the old wiring. Might take a week or so, but I'll keep you up to date
#407 ·
The pair of gray brown wires with no wrapping are the target of the picture. They come up out of the plenum where the starter is located. They are brittle from exposure to the heat. They are oily. But I see no breaking point. They were wrapped in plastic that I careful removed. They are not rubbing against anything so I'm thinking they are not part of the problem.
#408 ·
The four bare wires are the target of the picture. They are brittle and oily and they were wrapped in plastic. They don't appear to be broken.
I should mention where they enter their connector which sets vertical is exposed to oil. Same thing in the previous picture. They could be shorted out by the oil.
Any ideas or suggestions.
#409 ·
#410 ·
#412 ·
it is unlikely that those connections are causing your no start condition.
back to the relay......take your ohm meter set to continuity remove the relay and test for continuity between a ground and pin 86 when the key in in the crank position. it needs to be determined if the coil is getting a ground signal from the ecm.
it is possible that the problem lies in the ecm and you may just be chasing your tail jumping all over
