121 - 140 of 563 Posts
a bad module can also cause U1301 i believe
and if you can scan/view the individual modules it's easier to pin things down or eliminate them as an issue
spray that nut down with some penetrating oil and be careful not to go to hard looks pretty corroded....... maybe give it the once over with a wire brush
Discussion starter · #122 ·
Well I believe I discovered what is going on. I tried to remove that bolt on the EBCM and it just refuses to budge. It is corroded right to the frame of the fixture it is mounted on. So I tried heating it gently and I used penetrating oil on it, I even tried tapping on it and I took a chisel to it. It is really stuck on its frame. So I sprayed penetrating oil on it and I went back to the ECM to see if I could take it off and clean it up better. Its mounted on a not very rigid frame that has four bolts pertruding thru the ECM. I managed to get the nuts off before but I wanted to see if I could remove the module and clean it up better. So the nuts come right off but the module will not budge off the frame. The bolts are rusted tight to the module itself. I managed to get one bolt loose so I could verify it should come right off, but the other three bolts are rusted tight. Im thinking if there is that much rust that is probably the reason they are not making good contact.
My strategy is to spray penetrating oil on the bolts and run the nuts on and off until I can break it loose, but right now I am not seeing any progress so far. If I accidentally break the module, the car is a tow away.
IMHO,
You're chasing yourself into the ground
The ECM gets ground from the ground splice pack and has several clean grounds going into it
You MUST stick in your debugging to what the DTC is, which you state is a U1301
Do nothing else but look at that
Check the class 2 serial data line for a short to voltage.
With your voltmeter set to min/max. KO / EO
What is the max voltage you get from pin 2 at the DLC connector.
Red lead to pin 2, black lead to ground.
That DTC says there is a high when it should not be
I explained in past posts you have to stick with the vehicles network,
If pin 2 is high, you might start by pulling one at a time a controller out of the network
Check pin 2 and also see if U1301 comes back or not
If the problem does not go away, then plug it back in and pull the next controller and repeat until
Pin 2 goes low.
Something is shorted to the network line and that would kill that controller from functions on
that Starbus but also screws up other controllers
I do not know where the Starbus network is for your vehicle, most cases it is next to the BCM as it is the commander/router of the network
Should be like several wires laying flat and has flat connectors for controllers to connect to
Discussion starter · #124 · (Edited)
IMHO,
  • 1) So your saying the ECM is using the post #73 in Plug C2 as its ground.
  • 2) If that is true I can put the ECM back together
  • Its my understanding that an error has to occur somewhere in the system to generate a U1301
  • In this case a faulty groung could eventually create a U1301
  • I understand your thought process that I should track down the cause/ or what generated the U1301
  • Or in your words "Check the class 2 serial data line for a short to voltage."
  • With your voltmeter set to min/max. KO / EO
  • This is the Voltmeter I have there is no Min/Max KO/EO, so Im stuck
  • What is the max voltage you get from pin 2 at the DLC connector.
    I have not opened the DLC plug
  • Red lead to pin 2, black lead to ground.
  • That DTC says there is a high when it should not be
  • If pin 2 is high, you might start by pulling one at a time a controller out of the network
  • I have no idea what a controller is.
    But I understand your examination.
  • Something is shorted to the network line and that would kill that controller from functions on
  • Agreed,
  • I do not know where the Starbus network is for your vehicle, most cases it is next to the BCM as it is the commander/router of the network
  • I am working on the ground at the EBCM. the bolt is badly rusted and I need to get it loose and clean it up
  • This bolt is listed as a Ground for the ECBM
  • Image
One last point I wanted to make. I have the whole front end torn off the car so I can see most everything. I have found and cleaned all of the grounds in the Engine Bay except for the #8 on the pic below. It is the ABS ground. Thats what I have been working on the last few weeks. I just want to get it cleaned up so I can cross grounds in the engine bay off my list. It is my thinking that the root cause of this problem came from my recent work when I changed out the Catalytic converter. I was not having any issues before that. All of that work was in the Engine Bay.
Do NOT confuse the BCM, body controller to the
EBTCM that handles traction and ABS controller
If your multi meter does not store min/max then you simply have to write down what the min and max voltage you measure when trying to debug your class B problem
They call it a Starbus network, would be if you drew a line from one star to another, so they are in series
and then there is a return line to complete the data path, that would be the BCM
IF let's say star 2 (controller 2) or its wiring gets screwed up than it opens up that series path and all controllers suffer
The protocol the network using (older vehicles use GM's VPW and SAE's "CAN" each controller every few seconds puts out a SOH (State Of Health) frame, that is to let the other controllers know it is working fine.
If BCM does not see that from a controller it than that controller is no longer functional, when it really is, but the network is screwed up like in your case and simply that controller's SOH does not travel through the Starbus network
Without seeing how your controllers are wired for the network or what voltage is supplied, I cannot tell what would be the correct voltage to see on class 2, but I suspect 5 volts or fewer ?
You should tell when you do your testcases is one by one taking a controller out of the Starbus and what you measure on pin 2 of the DLC what voltage change you see
Discussion starter · #126 ·
Sounds like you are saying a "Controller is a Module".
For instance the:
  • The EBCM is a module.
  • The ECM is a module
And if this is correct, my test procedure would be to unplug the EBCM and test to see if I have the correct voltage in teh system. Is this correct?
Discussion starter · #128 · (Edited)
Yes, pull one module at a time and test pin 2 for less 7 volts
Class 2 functions from ground
  • Well, I put the ECM back together and I apparently shook something up. I decided to hook up the Code reader to see if anything changed.
    First thing I notice was the key comes out of the ignition without using a tool. Not sure what I can conclude from that since the ignition switch was operational before that, it just would not allow me to remove the key.
  • So I hooked up the code reader and I have a bunch of new codes we were not seeing before.
  • P2138Accelerator pedal Position Sensors 1-2 Not plausibleGeneric Stored
    P06415 V Reference 1 CircuitGeneric Stored
    P2108Throtle Actuator Position PerformanceGeneric Stored
    U0100Lost Communication with ECMGeneric Stored
    P06415V Reference 1CircuitGeneric Pending
    P2067Fuel Level Sensor 2 Circuit Low VoltageCurrent
    U1040Lost Communication with EBCMFSC DTC
    U0100-00Lost Communication with ECMCadillac MIL
    MIL = Malfunction Indicater LampCheck Engine Light
Discussion starter · #130 ·
  • Using this video, I tried to start the process of testing
  • WITH KEY OFF
  • There is 12 volts on pin 16
  • Tested Pin 4 to 5 yes there is continuity
  • Tested Pin 4 to 16 yes 12 Volts
  • Tested Pin 6 to ground = no reading
  • Tested Pin 14 to ground = no reading
  • Tested Pin 5 to ground 5 millivolts
  • Tested Pin 4 to 16 Yes 12 volts
  • Tested Pin 5 to 16 Yes12 volts
  • Tested Pin 4 to 5 = 3 millivolts
  • WITH KEY ON
  • Tested Pin 4 to 14 = 2.6 volts
  • Tested Pin 6 to 14 = 150 millivolts ???
  • WITH KEY OFF
  • WITH KEY ON
I have stated multi times the U code is saying CLASS 2, the video you point to is testing the CAN buss
I have stated multi times you need to look at pin 2, and it should NOT be staying at 7 volts, should be ramping up and down
You need to work with this video, and again I mentioned you need to get to the Starbus network and use the test connector there as you see in this video but first is seen what pin 2 is outputting
Watch this video multi times if need be to understand how to determine if a module is bad, constant chatting or wire shorted
Discussion starter · #132 · (Edited)
  • In your video the man is Grounding one Probe and then he starts with the Positive probe at the first pin on the splice pack and he checks for a test reading that is modulating up and down. If the reading is not modulating up and down it likely has a problem. Then he moves to the next pin performing the same test. He seems to be saying you check all the pins.
In your commentary you say we should be using only Pin #2 The Buss Positive Pin. Can you explain?
Discussion starter · #134 ·
  • So I tested like the man shows in your video and these are my readings
  • #16 pin = 12 Volts
  • #15 pin Not used
  • #14 pin = 2.64 Volts (Chassie Ground)
  • #13 pin thru #7 are Not Used
  • #6 pin = 2.8 Volts
  • #5 pin = 135 Ohms
  • #4 pin = 0
  • #3 pin = Not used
  • #2 pin = Seems to be modulating from 0.8 to 1.9 Probably hung on a Low
  • #1 pin = Not Used
So it looks like we need to go back to #2 pin and start pulling Modules to see which Module is causing the problem
Yes, if the KO EO when you were testing and voltage is going up down but not going to 7 volts than
a short to ground you assume
You need to find the Starbus network and the test splice pack to take modules out of the network and then test each one of that pack to find who is causing this as you know if valid talking on buss the volts would be going to about the 7 volts
Not sure if this would work but instead of pulling the cap of test splice pack is
what if the fuses for modules one at a time, would the low voltage on pin one go away ?
Maybe not as if it's a wire shorted to ground, it still is even if the module's fuse is pulled ?
Might be a quick test to find that out but if you have easy access to the Starbus test pack
I would test there
Discussion starter · #136 · (Edited)
Yes, if the KO EO when you were testing and voltage is going up down but not going to 7 volts than a short to ground you assume
NEW EDIT
I would test there
  • I don't know what a Starbus is, or what it looks like
  • I assume a Starbus is a wire harness
NEW EDIT
So I Performed the test we talked about, Pulling the Controllers/ Splice Pack out of the modules and see if one of them causes a change in the low readings
  • Just to be clear the original reading I got when I tested the DCL at pin #2 was .8 to 1.9 fluctuating, so we decide it was likely a wire to ground but at what module.
  • The ECBM controller made no change when I pulled the Splice Pack Connector
  • I pulled the Connectors for the Cam Sensor and Mass Air Flow connector, only because I had re-wired both of them. Just wanted to be sure they were not part of the problem.
  • I pulled C1 Top connector on the ECM and it had no effect
  • I pulled C2 the middle connector on the ECM and the reading changed drastically. The new Reading jumped to eight (8.54)
  • I pulled C3 the bottom connector and it had no effect on the reading
  • I pulled the connector for the transmission Control module and it had no effect on the reading.
  • So I assume we can conclude there is likely a short to ground in some of the wiring to the C#2 connector. How do we determine what wiring is leading into the C#2 Connector?
PinWire ColorCircuit No.Function
1-2----Not Used
3D-GN485TP Sensor 1 Signal
4PU486TP Sensor 2 Signal
5-7----Not Used
8L-GN432MAP Sensor Signal (I worked on this)
9----Not Used
10YE573CKP Sensor 1 Signal
11L-BU1876Knock Sensor 2 Signal
12GY23Generator Field Duty Cycle Signal
13GY1716Low Reference
14L-GN5282CMP Actuator Solenoid Control Exhaust Bank 1
15-16----Not Used
17TN1744Fuel Injector 1 Control ( I worked on the Fuel Injector Fittings)
18OG/BK1745Fuel Injector 2 Control
19D-BU496Knock Sensor 1 Signal
20L-BU/BK1746Fuel Injector 3 Control
21OG/BK877Fuel Injector 7 Control
22L-GN/BK845Fuel Injector 5 Control
23YE/BK846Fuel Injector 6 Control
24D-BU/WH878Fuel Injector 8 Control
25D-GN5273CMP Sensor Signal Exhaust Bank 1
26----Not Used
27BN/WH5303Low Reference
28GY2303Low Reference
29PU5284CMP Actuator Solenoid Control Intake Bank 1
30YE/BK844Fuel Injector 4 Control (??) not sure about this
31OG/BK5272CMP Actuator Solenoid Control Intake Bank 2
32OG5275CMP Sensor Signal Intake Bank 1
33D-BU530012-Volt Reference
34WH/BK5283CMP Actuator Solenoid Control Exhaust Bank 2
35TN5301Low Reference
36OG/BK469Low Reference
37TN2752Low Reference
38TN2761Low Reference
39BN/WH2130Low Reference
40L-BU530212-Volt Reference
41PU574Low Reference
42BN2129Low Reference
43PU5274CMP Sensor Signal Exhaust Bank 2
44TN582TAC Motor Control - 2
45GY5296Low Reference
46L-GN529812-Volt Reference
47BN5299Low Reference
48YE581TAC Motor Control - 1
49YE5276CMP Sensor Signal Intake Bank 2
50L-GN186712-Volt Reference
51GY27015-Volt Reference
52-53----Not Used
54YE410ECT Sensor Signal
55D-GN/WH428EVAP Canister Purge Solenoid Control
56-57----Not Used
58PU2121IC 1 Control
59OG/WH2122IC 2 Control
60OG2127IC 7 Control
61L-BU2123IC 3 Control
62D-GN/WH2124IC 4 Control
63PU/WH2128IC 8 Control
64D-GN2125IC 5 Control
65GY27045-Volt Reference
66-67----Not Used
68OG225Generator Turn On Signal
69L-BU/WH2126IC 6 Control
70----Not Used
71YE/BK529712-Volt Reference
72----Not Used
73BK/WH1551Ground
believe this is a 2004 connector 2
So in your testing, you believe the short on class 2 is from the ECM ?
All class 2 on the Starbus and the splice packs for the modules shown here
You need to save these and then enlarge to see them better as this forum limits photo sizes
Go back and review my posts as I showed what each wire is for the ECM,
Look at the splice packs below for Starbus/Class b
ALL Class B wires are purple
When you tested for the ECM where the other modules plugged back into the Starbus ?
When you read pin 2 of DLC at 8 volts, was the voltage from ECM steady or was the reading jumping up and down ?
Look at that video again when they talk about voltage staying high of a module
Discussion starter · #139 ·
  • When you tested for the ECM where the other modules plugged back into the Starbus ?
  • When you read pin 2 of DLC at 8 volts, was the voltage from ECM steady or was the reading jumping up and down ?
  • Look at that video again when they talk about voltage staying high of a module
  • By the way, the ignition was in the ON position.
  • Yes, I plugged each module back in after I tested it and before I tested the next module!
  • The voltage at 8 volts was steady.
  • Will check out the high reading in the video.
So that would mean the ECM outputs about 8 volts constant, so it does not shut UP
the prevention the other modules cannot talk via class 2 on Starbus
As you recall from that video modules talk, then voltage goes to like 0, another module than can talk but if ECM is always high and hung up
Watch video from like 5 to 10 minutes into the run
