501 - 520 of 563 Posts
Discussion starter · #504 ·
Never give up guys. thought you might want to know how this played out.
I finally got the 2004 SRX back on the road again.
Last time I talked with you guys you were pushing wring diagrams on me. I don’t relate well to wiring diagrams, so I proceeded with ERROR codes.
The car was not starting so I developed a work around. I pulled the started relay and crossed the two points to start the car. It worked. The problem was it was running in LIMP mode. It was drivable, but it had no power and would not go over 40 mph. Getting it started and getting it running made me feel good, even if it wasn't perfect.
So next I focused on error codes. This is a list of all the error codes I was getting. One by one I replaced the related parts:
  • The Accelerator Pedal Position Sensor, 09 / 06 / 2023, Shipped, $609.77
  • Accelerator Pedal Position Sensor, 09 / 02 / 2023, Shipped, $95.00
  • Throttle Body, 05 / 19 / 2023, Shipped, $116.61
  • Manifold Pressure (MAP) Sensor Connector, Manifold Pressure (MAP) Sensor, 12 / 29 / 2022, Shipped, $57.53
  • Camshaft Position Sensor, 12 / 29 / 2022, Shipped, $61.60
  • Vehicle / Output Speed Sensor Connector, 12 / 21 / 2022, Shipped, $88.35
  • Ignition Starter Switch, 11 / 21 / 2022, Shipped, $69.32
  • Lift Support, 05 / 13 / 2022, Shipped, $26.83
  • Ignition Coil, 05 / 08 / 2022, Shipped, $195.57
  • Oxygen (O2) Sensor, Valve Cover Gasket, Oxygen (O2) Sensor Socket / Wrench, 04 / 21 / 2022, Shipped, $242.87
  • An ECM from Flagship1 $200.
  • When I installed the new ECM all the codes automatically disappeared.
With all these parts installed it cleared all the codes. Then a day or two later a new code popped up
Code P00011. The check Engine light was back on again.
What is the engine code p00011?
What causes the P0011 code? The most common cause of this code is a faulty timing chain or camshaft sensor. It can also be caused by an oil leak in the VVT system, or worn engine components such as spark plugs, valves, and gaskets. If the fault code is caused by worn engine components, they need to be replaced.
I Took the car to a local repair shop, and they declined to work on it saying to get to the source of the problem, the timing chain, could cost thousands of dollars. They didn't want to be responsible.
I took it to the dealer for a second opinion. The dealer didn't want to touch it because it was no longer a Cadillac. I had made so many wiring repairs the dealer could not trust my work. He asked if he could keep the car over the weekend and drive it to see if he could get the Check Engine light to respond. The dealer advised me that it was unlikely the timing chain. He said the timing chain on the NorthStar is almost bullet proof. He advised me to recheck the wring. I was stumped.
The dealer called me and recommended a wiring specialist. The wiring specialist came to my house and together we looked at what I had done. He was impressed and baffled. He had the same problem; he didn't know if he could trust my work. Turns out, he was not really a specialist. He was in the business of repairing cars that were in accidents and needed new wiring, replaced. He was not good at diagnostics. But in the process of showing him what I had done I noticed that wiggling one of the wires on the camshaft position sensor caused the Check Engine light to go out.
After he left, I performed the same test and bingo the Check Engine light was out. The wire was grounding to the engine block.
I've been driving it for two weeks now, with no issues.
Discussion starter · #508 ·
guys I have intermittent issues with a female plug that fits into the area of the "Oil Control Valve". I want to buy a new plug and run new wires to it, but I can't find the name of the female connector. Any help would be appreciated.
Discussion starter · #511 · (Edited)
Team ZR-1 I went to their website to search for the Connector and pigtail I was looking for. I found some that look to be a close fit, but they have no "Search" tool, so it looks like it's a guessing game to find the connector I want. Is that the way it works?
This is very close to what I'm looking for, but I only need two wires.
This is the part that it plugs into
More Information for GATES VVS378 (rockauto.com)
what leads you to that conclusion, did you extract codes? or you just don't like the looks of that connection
if that is the vvt solenoid which it looks like it is, they are the listed connectors
if the problem is the wiring fix the wire hacks. that connector you show in the pic doesn't look like it should be a problem unless it's been improperly probed but the wire in pic 2 looks to be taped/spliced already?
solder the connections and use heat shrink tubing to seal them
Discussion starter · #516 ·
Very cool 1997_eldorado. I did what you did and found it. Turns out its a 2005 SRX V8
2005 CADILLAC SRX 4.6L V8 Variable Valve Timing (VVT) Solenoid Connector | RockAuto
Mine is a 2004 SRX, but im willing to bet it will fit.
It's not soldered or taped; the connector is broken. I think I may have probed it with a paper clip an accidently spreading the prongs too far apart. So it has a loose fit. Thats all that's wrong.
ya probing them is tricky. don't know why i was thinking 2007 sorry for the confusion.
i would not use those butt connectors, i would solder and heat shrink that connection and cover with wire loom. even if you use the butt connectors use heat shrink on them.
I would not suggest using those butt splices as that sensor either puts out a signal or low voltage
and butt splice might not do a good solid connection over time and could allow picking up EMI or RFI signals
Also, the wire loom wires maybe smaller gage and that butt splice could be for larger gage so not good crimp
Do a unit splice, solder and shrink tube and then some electrical tape around both for good seal
If having any electronic or MAF spray cleaner might as well clean the pins on the sensor
Discussion starter · #519 ·
Correct. I learned to solder and used heat shrink tubing. The car runs great, I think it could use new plugs but I lost my taste for tearing it apart and putting it back together. I'm just going to drive it for now.
Discussion starter · #520 ·
Guys thanks for your help, the connector I bought is exactly lthe right one, I soldered it on and shrink wrapped it. You could see the prongs on the old one were damaged when you compared them. I hope this is problem solved
