421 - 440 of 563 Posts
Discussion starter · #421 ·
So I ran the code scanner on it again and got some P codes. U Codes are all gone. Took the scanner back to Autozone and they could not interpret the codes. Had to make a trip to my local dealer and they interpreted the codes. After talking it over with the dealer service rep we decided the errors pertaining to the map sense and the accelerator pedal, we decided it most likely needs a new throttle body assembly. Ordered throttle Body from Rock Auto. Should have it by Tuesday
neither of those parts are going to help the no crank.
being the short running time it has had i wouldn't rely on the codes so quickly....especially to be buying parts
map sensor and accelerator pedal lead to needing a throttle body.......seems like some strange diagnostics but i am far from a pro
map sensor and accelerator pedal.......two areas where you have been messing around so i would again be looking at connections/wiring.
to me you are moving no closer to the no crank diagnosis.
i hope all goes well
Discussion starter · #423 · (Edited)
1997_eldorado
I agree and appreciate your opinion. I had these P codes right from thr start. It was saying my accelerator pedal position does not make sense. So when I showed the service manager he said he believed it had something to do with the throttle body and the accelerator pedal, they had to be in sync. I suspected this was a problem from the start. It may not improve the starting, but its necessary in order to run correctly.
The new diagnostic code reader gave a lot more detail than previous readers, code and statistics I never saw before, so since I had to visit the dealer for other reasons I took the code reader with me.
I will keep you up to date.
This was one of my first few postings about Codes
So it agrees with the service manager's idea. It may not solve all problems but hopefully its moves us in the right direction.
ok understand a bit
Code P2138 Cadillac Description
The Accelerator Pedal Assembly contains 2 Accelerator Pedal Position (APP) sensors. The APP sensors are mounted to the accelerator pedal assembly and are not serviceable. The APP sensors provide a signal voltage that changes relative to the pedal position. The Engine Control Module (ECM) supplies each APP sensor with a 5 V reference circuit, a low reference circuit, and a signal circuit.
Both the APP sensors 1 and 2 signal percentages increase as the pedal is depressed, from approximately 0 percent at rest to above 95 percent when fully depressed.
The Diagnostic Trouble Code (DTC) will be set when the ECM detects that APP sensor 1 and APP sensor 2 disagree greater than 10 percent for less than 1 s or the ECM detects that both APP sensor 1 and APP sensor 2 are 5 percent greater than the learned minimum position for less than 1 s.
there is accelerator pedal position sensors and i believe they do cause issues
and it is possible that a map sensor is not reading correctly but i can't draw the line to replacing the throttle body
Discussion starter · #425 ·
1997_eldorado
That's pretty much what we talked about with the dealer. When I used to take the car to the dealer for servicing, they replaced the throttle body regularly. I never knew why but they did. So now when we are getting these error messages I can see why they were replacing it so often
it still doesn't make sense to me to replace a throttle body when the APP sensor is throwing codes, i believe they the APP are a common problem.
to me the throttle body is an air pipe that dircects air and holds sensors and actuators....throttle position sensor, idle air sensor, throttle actuator that controls the throttle plate.
i think everything on the throttle body is replaceable/repairable
i was hoping we could get you started but that seems out of the cards
For one, as many times as battery was disconnected the problem could simply be that the Throttle Position Sensor (TPS) is required to do a relearn process for it as
Depending on if the gas pedal has 2 or 3 pots, GM has to do triple cross-checking that drive by wire (DBW) has not gone faulty and cause the vehicle to go wacko and cause a crash.
So if 2 pots APP, when off the gas pedal for example, one pot would report around 0 volts where the other pot shows 5 volts.
As steeping on pedal the 1 pot would be going from 0 to 5 volts (when pedal is to floor (WOT)
\where pot 2 is going from 5 to zero volts
This allows TAC (controller for DBW) to do a compare and to verify reading the TPS is also changing voltage output and TAC is doing compares to assure all is good
If the values of compare are out of specs than the PCM forces PCM to go into limp mode
It will not allow the engine NOT to start and TAC takes over and only allows a TPS angle like 20% and max speed of like 20 MPH
This is done to allow the driver to get home safely but at those lower speeds.
Throttle body itself is not going to cause DBW the screwup, the TPS attached to it could, or the DBW motor
attached to TB.
Or again if wiring problems but since the OP has not complained of limp mode when driving the car then TAC must be OK
BUT if TPS has not been relearned, sync'd with PCM then it could be reporting TB butterfly at xx angle but APP states otherwise
New TB alone will not fix this, nor prevent PCM sending out the control of start relay be reference to ground to negative of that relays coil
Again shows why a decent OBD-II scanner is required to be simple to look at APP and TPS and see if they agree with the TB butterfly angle or not
Either way, I would do the GM relearn/sync process for TPS just to get that out of the DTCs tripping
In the end that maybe a different issue but not why starter relays coil is not getting the control ground
That is enough 2 finger typing for me . . .
Discussion starter · #428 · (Edited)
1997_eldorado, Team ZR-1
Well I just noticed something I didn't see before. When I turn the key to the start position, all the lights go out on the dash. Could the dam switch be bad again.
I didn't notice when this started but this has to be why power is not getting power to the starter. When I put that ground wire on the relay, we lost the click of the solenoid and that could be when the dash lights went out (guessing). I have no idea what would cause that but its the last time we had a click at the starter.
Looks like I may have to pull the ignition switch again.
Discussion starter · #436 ·
Innova Code Reader results 05/23/2023
  • Cleared all codes as much as it would allow me
  • Re-Read Codes
  • P2122 Generic Stored
  • The APP sensor 1 voltage is less than 0.84 volts for more than 1 second
P2122 (1 of 5) Accelerator pedal position Sensor 1 Circuit low Voltage
  • Fuel sys 1 OL
  • Fuel Sys 2 OL
  • Calc Load (%) 100
  • ECT (Degrees F) 129.2
  • STFT B1(%) 0
  • LTFT B1(%) 4.7
  • STFT B2(%) 0.0
  • LTFT B2 (%) 7.8
  • MAP (inHg) 5.6
  • ENG RPM 0
  • VEH SPEED 0
  • SPARK ADV(DEGREES) -23.5
  • IATF(DEGREES) 242.6
  • MAF (lb/min) 0.0
  • TPS(%) 16.9
  • RUN TIME (SEC) 0
  • COMMAND EVAP(%) 0.4
  • FUEL LEVEL(%) 50.6
  • BARO (inHg) 27.8
  • ECU Volts (V) 12.1
  • Load Value(%) 0.0
  • EQ Ratio 0.999
  • Rel TPS (%) 6.3
  • Ambient (Degrees) 237.2
  • TPS B(%) 16.9
  • ACC Pedal D(%) 19.2
  • ACC Pedal E(%) 9.89
  • Command TAC(%) 8.6
P0641 (2 of5) Generic Stored
5 volt reference 1 Circuit
P0106(3 of 5) Generic Pending
Manifold absolute Pressure (MAP) Sensor Performance
P2122(4 of 5) Generic Pending
Accelerator Pedal Position Sensor 1 Circuit Low Voltage
P0641 (5 of5) Generic Pending
5V Reference 1 Circuit
The only thing I can say is the U codes are gone.
i believe it is just cycling the key on then off a number of times with the accelerator pedal in the idle position.......i don't remember the number and it may be different on the srx than my eldorado
As the way this thread has gone, I posted to OP what causes DBW/APP problems
I mentioned that the TPS needs to be relearned/rezoned and OP goes off on idle relearns
Idle relearn is another subject, what needs to be done is the TPS relearn to assure APP is in sync with TPS and TAC
OP does not give enough detail, so I do not know which design his TB is
In most cases, to rezone TPS angle to the PCM is
disconnect the wiring connector from TPS
Turn Key On, Engine OFF
Since the PCM cannot see signal from TPS the PCM zeros TPS angle to zero of butterfly and trips a TPS DTC
Turn key OFF
Plug TPS wiring connector back in
Clear DTCs, best is having a OBD-II scanner plugged in and look at the TPS PID with key on, engine off
should be reporting from maybe 0 to 10% angle, if so that proper rezone was done
that scanner may not handle u codes.?
without the car running for an amount of time codes aren't really dependable
also a low battery will throw some false results.
recheck all the wiring connections
The OP needs after all these months on this just not post scanner data but analyze it
1. Claims IAT is 242 F degrees, must be one hell of a hot day, ECT is only 129 degrees and reports
2. just key on, engine off, reporting TPS 16 % angle
3 Calculated engine load 100%, PCM uses MAP and MAF in part to calculate that but
the problem is the engine was not running.
4. States voltage at PCM is ECU Volts (V) 12.1, tad too low for PCM or any controllers to properly function
5.
  • Command TAC(%) 8.6 does not look valid
I mentioned way early in this monster thread that the 5 volts circuits need to be checked as some of those functions like MAP, TPS, APP, etc, function off the 5 volts the PCM produces, and the OP needs to go through the GM wiring schematic and see where the problem lies
