My blinkers stopped blinking - the hazards still work - and I need
to know where to replace the blinker unit plug on
a '92 Seville. My local dealer wants $75 to check it out and $50 to install the plug I bought. Any help?
2001 DTS, 2005 Mustang GT, 2010 MINI S
BUILDINGCTSAMG said:
check the fuses....should take about ten minuts and that prolly it...
The Cadillacs use a electronic blinker. Its a relay/module style unit. It is located on the left side of the steering column clipped to a bracket. Little bit tricky to find. Nevermind everyone else seems to use the .50 version just fine...anyways...
Being I bought a 2001 Deville my '93 SLS is for sale. Of course during a potential test drive the GD blinkers quit working. I found 2 bad solder joints on the circuit board of the flasher/module unit. Flashers now work...and the car is still for sale.
It really comes down to either the flasher/module or the turn signal column switch. Much easier to replace the flasher/module then the column switch.
I think the module can be had for about $20. You may have a greedy dealer.
Logan
