1 - 2 of 2 Posts
1996 ESC
I just changed the blend door motor .. my car was blowing hot air out 2 vents and cold out the others .. its put back together and doing same thing...theres no current codes ,, any ideas please n TY
need MORE - SPECIFIC - information -
which side blows cold -
which side blows hot -
is it actually HOT - or just hotTER than the other side -
do the vent temps change if you adjust the cabin air temp -
the mix door actuators move the doors that direct air flow through
either the heater core or the evaporator core
there are TWO of these actuators -
one for the driver side and one for the passenger side -
WHICH of the TWO actuators did you replace?
is the arm of the actuator connected to the mix door -
do the mix doors move freely -
did you observe the mix doors move as you adjusted the cabin temp settings from HOT to COLD -
if you disconnect the mix door actuator and manually move the mix door to the full COLD position
do you get cold air from the selected vents -
1 - 2 of 2 Posts
