Replaced the two front calipers and I can't bleed the brakes.
Using a vacuum bleeder; nothing comes out.
I know the ignition needs to be on to bleed the rears, but the fronts, I thought, bled like regular brakes.
Oh, this is a Teves setup.
2010 DTS
I've never bled front or rear with the engine on. I usually use the old pedal pump method. Never had much luck with the vacuum method.
Teves brakes are 'different'.
Your foot pedal releases high pressure fluid from an electric pump to apply the brakes.
