I decided to change out my old worn out shocks for some Bilstein 4600HD off-road shocks.
The job was fairly easy. The front shocks was a bit tricky to remove and tighten because you have to hold the piston from spinning when tightening the bolts. I decided to remove my fender liner to have better access.
I have hopefully disabled the RTD active suspension system by removing the negative battery cable and then the RTD fuse. I have not connected the battery yet, nor did I test drive the Caddy to see how the shocks feel yet. I will do so tomorrow.
Here is the stance
Old vs. new shocks
Shocks installed
My method to remove and install the front shocks. I used vice grip pliers and a racketing 17mm wrench(15mm for the stock nut).
I remove my old rear springs, but reinstalled them because the springs were good and the new ones seem like they would be too stiff with my Timbrens bump-stops.
Timbrens bump-stops and spring being compressed
Moog rear springs(top) vs. OEM springs(bottom). The Moog springs has two more coils, but is the same height as the OEM springs.
Here is the stance
Old vs. new shocks
Shocks installed
