1 - 8 of 8 Posts
2005 & 2008 CTS
Robert,
You got a link? I checked under cadillac parts, cadillac cts parts, cts parts and got nothing.
2005 & 2008 CTS
Sounds interesting.
Todd - Thanks but I was interest in a price of 14" rotors and caliper mounting brackets.
07 SRX V8 AWD Diamond White Sport Edition & 08 C6 LS3/418ci
05CTS said:
Robert,
05CTS:
Here is a copy of the original thread that was posted on our custom built Cadillac CTS Big Brake 14" Rotor Kit. There are many, many options available specifically for the Cadillac CTS 5x115 Hubcentric bolt pattern.
The most significant difference is that our rear Big Brake rotor kit is available in 14" and requires absolutely no modifications to the rear spindle or knuckle which would potentially preclude you from ever returning the vehicle to it's stock configuration when you resell the vehicle or trade it in.
With our rear kit; it simply bolts to the existing the existing spindle and your ready to roll without any grinding or special fitment modifications that compromise the structural integrity of the rear spindle. The advantage of course is that you can remove our rear 14" big brake kit when your ready to trade in the CTS and reinstall the OEM rear brakes and possibly resell your rear kit and recapture a large portion of your original investment. If you grind away your rear spindle and install a kit that requires that type of modification; your CTS has to leave with a modifidied braking system that could affect your trade value. The bottom line is that whatever you install; should be able to be removed without leaving any residual damage or changes to the vehicles suspension geometry.
Please email us for any additional questions that you might have as I belive that from a price, quality and simplicity of operation standpoint; you will find that out CTS Big Brake 14" front and rear kits offer options that no one can match.
We look forward to hearing from you and exceeding any expectations that you might have. Every CTS big brake package form Cadillac MotorSports, Ltd carries an unconditional fitment guarantee with no restocking fees and Free UPS Shipping and Insurance.
Ask those who have bought rotor packages from Cadillac MotorSports and they will attest to the quality, fitment and unconditional after the sale support that is provided with any of our products designed, engineered and fully tested for compatibility with the Cadillac CTS.
Thread: CTS Big Brake 14" Rotors ( 5x115 ) Bolt Pattern!
View Single Post #1
12-19-05, 09:42 PM
Cadillac Fan
Finally there is no need to dig through the CTSV scrap pile in search of an affordable front and rear CTS Big Brake Rotor Kit designed specifically for the Cadillac CTS.
No need to replace your 5 bolt aftermarket wheel/rims with 6 bolt CTSV OEM rims or worse yet having to purchase a custom set of 6 bolt rims, new spindles, hubs etc.
With this Custom designed front and rear 14" CTS Big Brake Rotor Kit all that is required are a set of 18" rims.
That's right! No spindle or hub swapping and no new 6 bolt wheel rims or custom high dollar aftermarket wheel rims!
You simply remove those puny OEM rotors and replace them with our custom designed 14" Cadillac MotorSport CTS Big Brake Rotor Kit.
Just think about it......14" nickel plated 5x115 big brake rotors designed and engineered specifically for the Cadillac CTS that are far superior in their design and engineering when compared to the GM sourced one piece Brembo 14" heavy cast iron V rotors!
Here's just a "tidbit" of information with some details that will leave you screaming....."what is CMS working on next?"
We have a 14" big brake rotor kit for the Cadillac CTS that features our proprietary directional sport vanes. They are constructed of forged alloy steel and available in either a cross drilled pattern or slotted pattern. As usual; we cryogenically treat these 14" rotors and heat temper them and guarantee them against warping and/or cracking.
These CTS Big Brake Rotor Kits are available in 2 types of configurations that have the CTSV fellows just salivating!
  • 2 piece configuration with solid billet aluminum rotor hats. These are the Cadillac CTS Super Sport Rotors and weigh 7 pounds less than the solid one piece 14" rotor. All of the hardware that is used to mount the solid billet aluminum front and rear rotor hats is aerospace grade titanium hardware! This kit is designed for the true spirited driver where unsprung weight and lightweight alloy wheel rims and weight savings are a priority!
  • 1 rotor piece configuration with all of the same features above for those that are looking for a true 14" big brake rotors to fill out those 18, 19 and 20" 5x115 wheel rims! This kit is known as the Cadillac CTS Rally Sport Rotor Kit. And if your looking to save some money......the one piece Rally Sport kit will be priced at about 40% less than the CTS 2 piece Super Sport big brake kit with all of the same features!
Heck, we'll even let you put the 2 piece 14" Super Sport Rotors on the front of your CTS and the money saving 1 piece 14" Rally Sport Rotors on the rear!
So think about it all of you California lovin' 20" wheel rim low riders that have those perfect 20" LA wheel rims! No additional investment in new 6 bolt wheel rims and no scrap yard CTSV spindles and hubs!
Finally; a true custom designed 14" CTS big brake rotor kit available in both the Super Sport (2 piece kit) & the Rally Sport (1 piece kit) version designed and engineered specifically for the CTS in the correct hubcentric 5x115 bolt pattern!
So if your riding on 20's and are at all suffering from "little rotor size complex"; then Cadillac MotorSports, Ltd has the solution at prices and options that will amaze you!
All you need to add to complete the look are a set of Brembo CTSV brake calipers available from GM Parts Direct and your ready to roll!
Or you may use your existing CTS OEM PBR brake calipers with our custom machined brackets with your new CTS 14" Big Brake Rotor kit and have no further investment if it is just big rotor size that you are interested in to compliment your large wheel/rims.
There is a solution and application for every budget and application!
No one offers more for the Cadillac CTS for less than Cadillac MotorSports, Limited.
To learn more about this kit, its pricing, availability and custom options; all inquires must be directed to:
[email protected]***********************
We are the exclusive North America manufacturer of the following:
  • Cadillac CTS Super Sport Rotor: (14" 2 piece)
  • Cadillac CTS Rally Sport Rotor: (14" 1 piece)
  • CTSV Magna Sport Rotor: (14 & 15" 2 piece)
The above CTS rotor discs are designed specifically for the Cadillac CTS 2.8; 3.2; and 3.6 sedans with the correct hubcentric 5x115 bolt pattern for both front and rear brake disc applications. 18" wheel rims are required for proper rotor disc diameter clearance.
The CTSV Magna Sport rotor discs are designed specifically for the 6x115 hubcentric bolt pattern in both the 14 and 15" rotor disc bolt pattern and will fit the CTSV OEM wheels or any custom 6x115 hubcentric wheel rim with the same CTSV OEM rim offset.
All inquiries regarding these products are to be directed to:
ALL PRODUCT INQUIRIES MUST BE DIRECTED TO CADILLAC MOTORSPORTS DIRECTLY.
1 - 8 of 8 Posts
