1 - 20 of 22 Posts
2007 Escalade
Looking around online I havent found many options for cross drilled/slotted brake rotors for the 09+ V. Typically you will find hundreds of options on Ebay but I only noticed one company selling them for the rear only. Was hoping to buy a set for all 4 corners with pads for a reasonable price...maybe a grand or less?
'85 Sedan de Ville, '10 CTS-V
D3/ALCON makes a set. Gotta add an extra 0 to the end of your budget ("a grand") though... But maybe they're on sale...
2009 CTS-V (TR-6060, Black Raven/Ebony, Recaros, Ultraview)
The reason why the V2 didn't come with cross-drilled or slotted rotors is excessive pad wear.
Good luck. no options yet. Have no idea why brembo doesn't make a matching rear set to the fronts they are currently offering!!!
Sorry, didn't read the original post carefully. You just want replacement rotors. I saw rear Powerslot rotors on Tirerack. Wonder why no front?...
09 Cadillac CTS V
The rear rotors are also used on other vehicles. The front rotors have been exclusive to the Cadillac V series so far. The rumor is that the new ZL1 Camaro will also get our front rotors. When this happens, we should begin to see more options available from 3rd party manufacturers.
NONE
So how about some people comment on what they would like to see in upgraded 'V rotors? I'm involved in a project that could benefit from owner input. Thanks!
Chris
NONE
Chris- CCM like on a ZR1.
Can do! But it would be a full 3-D weave, not the three laminated sections like on the ZR-1. The solid CCM material is much more user friendly and can be ground if ever oxidized. The ZR-1 discs are throw-aways once oxidation sets in.
That'll be about $17k per car as long as there are enough deposits down to start the run, which is at least 10. Are you #1?
Chris
09 Cadillac CTS V
Chris
2 piece rotors with replace-able rings. Preferably with some form of gas venting and costing around $650/set. They will need to keep up with the heat from a tight road course and a heavy car. Am I dreaming?
NONE
Can they be made? Yes. Can they be made of the appropriate material callout, heat treatment, finishing technique, etc., to live under such a heavy, high-horsepower car for track use? Yes, but probably for about $1100/pr retail. The first pair will cost more due to the aluminum hat (+$450 maybe?), but after that it would be rings only.
Sorry, but that is just the cost of making good, high-quality iron these days. I have extensive experience with a very similar Brembo system (Nissan R35 GT-R) and can say all issues were solved with the appropriate choice in materials. Those guys went from 1-2 track days before cracking the OE discs to 6-12+, depending on the particular track, pad choice and driver. The same can be done for the CTS-V, but not for $650.
Chris
1959 Cadillac, 1980 Cadillac,Former 2005 CTS-V; now a 2009 V
That doesn't make sense... on my 05 V i had crossdrilled and slotted rotors for several years, and never had a problem with pad wear. Granted i never tracked my car, but i dont' see the 09V being that much different when it comes to pad wear... the GenI V had smaller rotors and was lighter. The new V has larger rotors and is heavier. I wouldn't think it would be too big a difference.
Rotorworks offered EXCELLENT rotors - have been very impressed with them. But of course they don't offer any rotors for the new generation Vs =(
NONE
The current 'V has front rotors that are in a different class than the last 'V -- 2-piece dual-cast versus 1-piece (BIG difference). To make an upgraded rotor withstand the usage that some will put them through takes one of the better racing iron compositions. This was the lesson learned very well on the GT-R, with its nearly identical Brembo system and the same type of soft, high-carbon iron rotors. That type of iron helps with noise reduction, but it makes a poor track part. In my experience, you won't see the lower tech or copy-cat companies tackle applications like this as it requires actual engineering and specific metallurgical experience, or they would risk it becoming a very expensive experiment with unpredictable results.
It's great you've had a good experience with the rotors you mention, but I do know where they get their blanks (regular, low-cost Chinese and Taiwanese stuff) and the machining patterns shown on their web site are far from optimized for pad and rotor life. They are the typical eBay-type seller that has a wholesale brake parts account and a milling machine, but no real engineering.
An upgrade for regular street use can be solved easily by procuring OE blanks and machining them (if done properly!). But the cost of doing that might likely approach a true, dedicated solution. I'll check on that tomorrow, time permitting.
Anyone interested in a matching 2-piece rear rotor upgrade, if possible?
Chris
I guess that's the difference - you're talking for high performance, track use. I've never taken my car to the track and don't really ever plan to, so for me, for several years, the 'cheap' drilled/slotted rotors have been great.
NONE
Yes, exactly. On the 1st Gen V, that option was available. I could be wrong, but I don't see that happening any time soon on the 2nd Gen.
Chris
2007 Escalade
Discussion Starter #18
If anyone comes across an option to have our stock front rotors drilled/slotted by a private party company I would definately be interested. Since nobody sells them yet it may spark interest in a group buy if offered with decent turn around time...
09 Cadillac CTS V
Chris_B -
Have you had a chance to look at the Brembo Track rotor? It is a 2 piece, but they won't sell rings for replacements. Will yours differ much, and how? I need a set of Rotors for HPDE events soon. I can get by with the current rotors for only a couple more events.
NONE
Chris_B -
Yes, I have. They are pretty nice units that come in plain face only, at least at the current time. I'm told the lead time right now is 3-4 months, and list price is $1295/pair for complete assemblies only, just as you say.
I have identified a perfect option to go to, which is a significantly better iron composition, the type that was used in NASCAR until just a few years ago when a newer (and even more expensive) version was released. If we do something, we will attempt to keep it down around that same pricing, but it will be a difficult task with the better iron and either J-Hook or slotted patterns. They would also require a small caliper spacer as they are slightly larger in diameter (380mm vs. 370mm). However, the more demand, the greater leverage with manufacturing.
Chris
1 - 20 of 22 Posts
