1 - 8 of 8 Posts
93 deville
just replaced the bcm due to the digital dash cluster not displaying anything. the new bcm light up everything bright when i first put it in and then went dim and i lost the display to the temperature display and fuel display.
so i went over to the bcm and it was VERY hot to the touch. also i dont know if it was just me but it seemed like even with the car off it continued to get hotter. so id uplugg let it cool and try again. same results dim dash lights no fuel or temp displays. anyone have any ideas
93 deville
ok will do that whats the easiest way to remove the dash? i see some screws up by the air vents does the wood trim need to come around the displays?
93 deville
just got the top of the dash and the wood grain removed will start pulling the displays tommorrow morning as it is getting dark around here.
93 deville
it turned out to be the ecc, replaced that from a junk yard dash lights stay on bcm dosent get hot and seemed to fix battery drain
1 - 8 of 8 Posts
