00 cadillac deville
00 deville Battery not charging warning comes i tried to start it it wouldn't
i let sit 30 minutes and i started but 5 minutes in to driving the warning comes back on i figure its the alternator.
2000 DEVILLE,2001 STS.
Pull the codes to make sure it's your alternator.I replaced mine a few months back on the wifes DeVille. Code po621 came up ( L-terminal circuit problem )
The Alternator is kept cool by engine coolant. I had to remove the Rad/Fans to replace. Not too hard to replace but a little more work than the average car.
1996 Deville LaSalle edition
You might also check your connections at the alternator and the battery. Could be just loose or corroded.
Liquid cooled alternators where only used for 2 or 3 years.
I guess the case has a water jacket that has an inlet and outlet line connected to the water pump or some point in the cooling system.
