Could be your alternator...
There certainly is an easier way. Use a screwdriver to trip the latch on the door. I do them all when I know I will be in and out of the car for hours.....
So what I've done so far is pull the back bench and unhood the rear fuse block. Oh what a pleasure to try and troubleshoot such a "smart car". I'm literally crawling in and out of my window so as to not trip the timers, relays and whatnot. Yeah yeah I'm sure there is a smarter way.
So I could have been wrong...Dome/interior light switch should not be a problem unless the lights were on all the time, but even then battery rundown should have kicked in.
Ten ma is an acceptable reading (my '98 settles down to 30 ma). A fresh battery fully charged should sit for 6 weeks or more and be able to start the engine.....
10 mA steady state? seem right? Not sure if I trust the meter but that's what I'm getting - I think.
The door latch clicks twice for the closed and latched position. And it sounds like you are done testing for parasitic drain anyway.JimD: Not sure if I buy the "trip the doorlatch with a screwdriver" since my dash computer reports the door as open even though I have the latch closed. Hence I am still doing my tests with doors shut.
