1 - 16 of 16 Posts
Sedan DeVille 1983
Hi everyone.
i'm Roberet from Paris France
i got a Sedan Deville 1983 V8 4.1 gas
i have to change the batterie, unfortunatly here we can't find the bateries for such big engines. the Ah or Amp are always too low. or the size is too big.
so i found on internet a seller of OPTIMA bateries. any knows ?
he told me that the baterie with Yellow Top would be perfect for my Caddy, the model Y TS 4.2
but the problem is the it's a 55Ah 765/870 ... the baterie that i'm suppose to have on this car is a 78Ah 675/840
so does 55Ah are ok for this car ??? what could be the problem ?
I've heard also about the exepensive ODISSEY bateries. but same problem, lower Ah.
thanks for helping me ASAP
2014 ELR
The Optima type batteries are not good for a car that sees occasional driving. If they discharge, they can't be recharged.
Stock battery is series 75, the bigger 78 will fit. Realistically, anything that fits and has the side posts in the right spot will work fine.
Sedan DeVille 1983
Ok. And what about the ACDelco but 115 Ah and 840 / 1000 A with the spot in top and + on left just has i need and that fits the baterie location ?? 115 ah aren t too much ? My alternator is a 80amp.
Let me know cause i m ready to buy it ! I need one !
And what are the series 75 78 ?? What brand ?
Ps optima says on their site that the baterie can be recharged.
1981Cadillac Fleetwood Brougham D'Elegance Coupe m
I put an Optima Red Top in my 81 with 6.0l and I just love it. I have had the battery discharged on a number of occasions because of a current draw and the car sitting too long unused and still charges up fine. This battery will crank and crank and crank. The AC Delco battery I had just wasn't doing the job.
Sedan DeVille 1983
Hi. Thanks for answering. a red top ok but why not a yellow top ? can you let the doors open for while. ? Or stay in your car to listen to the radio with the motor is off. ? i know Optima and Odissey are perfect to start... But.they don t have.lots of power in reserve. so i m lost.
And about the red top, the size won t fit my car i guess
Yellow tops are deep cycle batteries. For use in vehicles with a lot of electronics, vehicles with high powered audio systems, or in situations where the battery will be discharged more than normal. Yellow tops have more reserve, but LESS CCA than red tops.
FWIW, any battery will go dead of you listen to the radio with the car off for long enough. But if your battery is dead after only 10/15 minutes of having the radio on, or a door open, you either have a defective battery, or a drain.
Sedan DeVille 1983
Discussion Starter · #7 ·
Well i see what you mean. So for this Caddy with a regular Radio CD player and blutooth that i dont drive too often, maybe twice a month in the winter time.
what would you use ? A red top if it can fit my car ...but too expensive for me i guess... Or a yellow top yt s 4.2
or at least an ACDelco 78 ah 840/1000 cca i guess
For.info here in paris my car sleeps in a private garage..not cold. And if i use it in winter it wont be under minus 5° celcius.
Thanks for help. Due to the price of such baterie here about 300$ i dont want to make any mistakes. the acdelco is same price than optima here. But optima is 55ah and acdleco 78ah... So what to do
Just get a good quality, lead acid battery. It doesn't HAVE to be AC Delco.
When the car is left to sit, is it anywhere near a power outlet? If so, spend the money you saved on a battery float charger/maintainer.
Sedan DeVille 1983
Discussion Starter · #9 ·
No infortunatly no power outlet near the car. It s a Common parking.
So you think acdelco is not as good as others ? got inly two choice acdelconor optima... But 55 or 78 ah
Oh no, AC Delco is great. But there are batteries that are just as good, that are less expensive. If those are your only choices, I'd get the AC Delco.
86 DeVille (RIP), 89 Brougham D'Elegance (RIP), 95 FWB (RIP)
My two cents: I put a Duralast Gold in my 89 about 7 years ago. Still hasn't let me down. Even on a couple of occasions where the car sat a week or more without being driven.
Sedan DeVille 1983
Discussion Starter · #12 ·
Sounds intersting..brand is Duralast ?? Not sur to find it here. but the important thing..how much Ah is yours and what should it on the dacillac informations??
It's AutoZones house brand. US only.
Don't worry too much about AH. Your electrical system isn't very demanding on the battery, you don't need a super battery.
Is Bosch available in France?
If you're really concerned with the output a Bosch Premium group 75 is rated at 730/910, and a group 78 at 770/950.
The best AC Delco Professional group 75 is rated at 735 CCA, the group 78 at 770.
If you can get a Bosch cheaper than an AC Delco, I'd go that route.
Sedan DeVille 1983
Discussion Starter · #16 ·
Well..thanks a lot. I will go to the baterie store to see what they can.offer. thanks for help to all of you. Rob
1 - 16 of 16 Posts
