10-30mph and step on the gas here and feel bang from the floor or firewall?
doesnt do it at high mph just lower. Or when driving in stop and go driving on interstate.Trans or motor mount or???? cars runs good still other wise 87500 on it.
Ranger said:
Motor mount would be the first suspect.
yes, check the 2 dog bones that keep the motor from rolling front to back. They are easy to take off and check. If the rubber is even the slightest bit cracked, it is allowing the motor to roll under torque.
They are availible from all parts stores are fairly inexpensive.
Just remove the 2 long bolts on each end. They go back together as easy.
Good luck.
94 Eldorado, and a 99 ETC
Before you take them off, do the wiggle test on them first. If you can wiggle them with them on there then you know they are bad already and you don't have to take them off twice (once to check and once to replace).
· Super Moderator
2010 DTS
I think a little wiggle is normal.
