So after swapping in an old set (probably a good 15 years give or take 5) of Pyle tweeters into my 97 DeVille, I get no sound. I know the factory tweeters were a different resistance and all, but I dont' get a snap crackle or pop at all (not even a hum). Can't believe I didn't take the time to test them before wiring them in and mounting them.
However, I can simply pull the actual tweeter part front ways out of the mount after removing the grating without removing the entire door panel and rewiring everything.
I wanted to see if you guys knew a way to check if the tweeters were good without cutting stuff apart and such. I heard you can use a DMM and just read resistance across it, but won't the reading be way off due to having the door speakers and the oem hu in the circuit the other way around? Also heard about a battery test but don't want to try that with the hu being hooked in.
Kinda odd question but if anybody could let me know if the DMM test will work then I'd really appreciate it.
