I have. It's not very easy. The manual suggests that you remove the bumper fascia. I ended up just removing the screws on the bottom without fully removing bumper. Stuck my hands in between the black plastic shielding and the bumper and did my work there. It took a bit of time because the light bulb was securely fastened...had to get some pliers to help me twist the bulbs out. Ended up brusing and scraping my arms because it clamped down on my arms so much. Looks a lot nicer with the white LED...since everything else is already white (I also switched up license plate light)
