1993 ETC, in Windsor, Ont.
Where is the backfire relief valve located??
I am having a host of problems mainly after a leaky injector o-ring caused a manifold backfire... all the symptoms of a massive vacuum leak.
Dan
93 ETC
If you're aksing about a 93, there is not a backfire valve. The grommets on the intake cover bolts were added to allow the cover to lift in the event of a backfire.
'94 is the same. '95+ is what Jim is describing. Don't feel bad Jim. I was about to make the same mistake, but you beat me to it. BTW, thanks. :highfive:
