01 DTS, 05 Vette, 09 Ram 1500
How do you remove the back seat? I think the battery is under their, but I actually need it removed to retrieve some small springs and etc. I dropped while working on the light above. (01 dts)
Thanks.
1989 Fleetwood FWD / 2000 ETC / 2000 STS / 2006 STS V-8 1SF RWD
Hello...
You only need to remove the rear seat bottom:
1. Push in and up on the front of the rear seat cushion.
2. Lift up and out on the seat cushion.
3. Disconnect heated seat electrical connectors (if equipped).
4. Remove the rear seat cushion from the vehicle.
2010 DTS
I know that was the method yeeeeaaars ago. I cannot speak for the Deville but on the Seville ('99 for sure) you just lift straight up on the leading edge, then slide the cushion forward.
