Back from another day at the track. The new power steering cooler did its job well. The fluid stayed well within spec and never caused a hiccup in the power steerings operation. The fluid also remained a light color and did'nt discolor like last time at the track.
At the end of the day I set out to really put it through its paces. I did a 40 minute non stop session includeing allot of drifting out of corners. From past experience this seemed to cause the most heat buildup in the fluid. Everything performed well.
Only "incident" was a drift that eventually tried to spin the car but I recovered.
http://www.techvelocity.com/gtp/misc/ack.wmv
Oh and I thought I had discolored the calipers on the "loaner V", thats nothing.
A little comparison:
http://www.techvelocity.com/gtp/misc/CTSVrotor.jpg OEM pads
http://www.techvelocity.com/gtp/misc/hotcali.jpg HAWK EP+'s
http://www.techvelocity.com/gtp/misc/hotcali2.jpg PAGID race pads
The PAGID pads where awesome. But they where mostly used up in 1 day. The best pad for the money/performance ratio in my book is the HAWK's.
At the end of the day there was only a small hint of differential whine. I do think the BMR pinion support did its job and kept everything in line.
I do need to lower the rear end. I felt it coming around in 90+MPH turns. I still say the GM wheel hop bushings affected the handling of the vehicle by raising the back end up nearly 3/4's an inch.
Aaron
Aaron
