2008 cadillac cts
how do i get my back doors to open when they are locked
2006 CTS-V
The back doors should have a pull tab on the lock to open.
This is for the 2004-2007 CTS V1 however and not for a 2008 CTS as it's different.
-Byron
'05 CTS-V
I'm assuming that you're asking about the '08 CTS listed under the username, so I've moved from the '04-07 CTS-V forum. Hopefully someone with the same generation of car as you can help you out.
Welcome.
There are pull knobs on the rear doors for manual operation, the unlock switch on the driver door or using the unlock button on your fob for automatic results.
Depending on your vehicle, some only require pulling the handle from the outside with fob on person for access.
Is there an issue you are experiencing that you could provide more details for?
2003 Deville Base
wondering if the OP means from inside or outside? It would make a difference.
Did you turn on your child safety locks and now can't get the door to open?
I had this issue in a 95 impala with broken outside door handles and we had to pull the door panels from inside the back seat and reach into the doors guts to switch the child safety lock off. No fun!
