Hi all,
I recently purchased a Euro spec 1998 Seville STS in the Netherlands, and drove it home to Norway, where I have enjoyed it immensely, apart from that one thing - air only blows from the defrost vent. Nothing from dash vents or floor vents.
I have the b1344 code. And so, I got hold of a new mode actuator , since I found that this is what said code means. Had a local mechanic put it in, but to no avail. Still the same. I was given the tip on the Northstar Cars facebook group that it could be the AC control unit in the dash that was giving out the wrong signal, so I got hold of one of those, but to no avail. Still the same. I have pulled fuses, touched battery connectors to each other, played with the mode button on the dash for long periods of time, but to no avail. Still the same.
So that, guys, brings me here. I have of course searched on your forum - it is, after all, here that I have picked up most of the tips I have tried to fix the problem. But I was hoping that someone might have the solution for me, as I am about ready to deposit the car in the ocean at this point.
Here are what little details I can offer on what the car does and so on.
I will also include the list of codes the car gave me last time, just in case.
amp u1255 c
ddm u1255 h
ipc u1255 c
ipc b1652 h
ipm b1344 c
ipm b1652 h
pcm p0603 h
rim u1255 h
So there it is, guys. Can anyone offer any insight on what more could be done to fix this problem, other than drowning the car in the ocean? I would really, really like to get the dash vents to work...
Thanks for any replies!
Best regards,
Jan.
- When the mechanic put the new actuator in, it went "all the way and stayed there", as he put it, which I suppose means straight to defrost. Never moved since. (Could the mechanic have messed anything up while replacing the actuator?)
- When I start the car, there is some sort of "almost clicking" sound from the driver's side of the dash - not like when gears are stripped, but a softer, lower type of clicking. Not even sure I would define it as clicking, but close. Almost like a low thump. It stops after a little bit. Air stays in defrost, does not change when car starts.
- When I try to change the modes, I hear slight noises from the dash which lead me to believe that something back there is trying to do something, but cannot.
- When I select dash vent mode, there is a slight clicking sound from behind the dash - not like when gears are stripped, but rather a single low, muffled click, followed by silence, then another, followed by silence, etc. No such clicks when it is in the other modes that I can hear. Also, it is a different noise from the other clicking sound I try to describe above.
- This probably has nothing to do with anything, but I notice the inside of the center console, close to the vents, is covered in some "sugar like" white stuff that is also present on the dash vents.
- Also probably has nothing to do with anything, but it does appear a new battery has been fitted to the car quite recently.
amp u1255 c
ddm u1255 h
ipc u1255 c
ipc b1652 h
ipm b1344 c
ipm b1652 h
pcm p0603 h
rim u1255 h
Best regards,
Jan.
