I finally installed the B&M shifter. I love the notchiness, it's exactly what I was wanting.
I only have one issue. Reverse is hard as hell to get into now. I have to push hard to the right and at a slight angle before pushing up into gear. Anyone else have this issue with reverse after the shifter install?
Maybe I was just spoiled by the mushy stock stick.
***UPDATE****
Problem solved! I couldn't get the damn knob off but was able to lift the shift boot over the knob enough to remove everything else.
I installed the bolt through the top instead of the bottom. From the top the bolt does not screw all the way in, leaving just enough space for the shifter base to lift up. I re-installed the bolts from the bottom and was able to firmly plant the base to the stock plate. Put everything back togethor and Reverse is a breeze!
I just hope I didn't do any damage to the tranny driving it around when I had the original problem.:hide:
***UPDATE****
