1 - 2 of 2 Posts
Metro cadillac deville tubo un problema al caer en un pozo, al páreser tie e un problema eléctrico el carro ensiende perfecto pero se apaga solo, al ensender la señal de peligro (intermitente) se apaga al instante, de igual forma si esta presionado el botón al ensender lo no arranca y se activa todo el tablero así como bajarse y subirse los seguros, fundió a la direccional izquierda, pero la derecha se queda pegada y prendida. Tanpoco sirve el botón de crusero
'05 CTS-V
Google Translate says...
Cadillac deville metro had a problem falling into a well, when the wall had an electrical problem the car turned on perfectly but turned off by itself, when the warning signal (flashing) was turned on, it turned off instantly, in the same way if the button was pressed When it is turned on, it does not start and the entire board is activated, as well as lowering and raising the locks, melted the left directional, but the right remains stuck and on. The cruise button is useless
So, I don't know what year and model you've got, but it sounds like it's not a CT6-V, so you've posted in the wrong forum.
1 - 2 of 2 Posts
