1 - 9 of 9 Posts
2011 Thunder Gray CTS Premium
does anyone have a way for blue tooth audio?
if not, if you use the aux jack, where do you route your wire? I haven't seen any notches so not to squish your wires.
2013 Black Diamond CTS4 Premium Coupe (sold-09 CTS4 DI Black Raven/Ebony)
Do a little searching, this has had some in-depth coverage in the past, including what worked well for other forum members.
2011 CTS Sport Wagon
i have a blackberry bluetooth gateway that i bought for a previous car with the same aux setup that works great in the CTS. Currently using it with a Samsung Galaxy S5.
This is the one I have - I bought it a few years back for $35, not sure why it's $80 now
http://www.amazon.com/BlackBerry-Remote-Stereo-Bluetooth-Gateway/dp/B00170KUM0
This one might work just as well:
http://www.amazon.com/BlackBerry-ACC-41596-001-Music-Gateway-Packaging/dp/B008736UWO
just leave it plugged in inside the center console - it will turn on with the car and auto connect to your phone.
2009 CTS 3.6 LY7
...watch out, on my '09 the console power outlet is NOT switched with ignition, it is on all the time. Think later years it became switched, not sure when.
yep, it definitely turns off with the ignition. There's a blue LED on the charger that goes on/off with the ignition. plus i've had it installed for about 6 months and no dead battery. I have a 2011 like the OP.
2011 CTS4 3.6
1 - 9 of 9 Posts
