VERY NICE! one question though, where did you buy the filter package at?
I got one from Napa. I'm sure there are other places around that sell them.VERY NICE! one question though, where did you buy the filter package at?
My friend works for GM so he got me all OEM parts for 50% off. But I'm sure most parts store have them.VERY NICE! one question though, where did you buy the filter package at?
Thanks, I wouldn't have had the cojones to do this work without all the help I received from members of this forum. Thanks guy!nicely done mann
No problem, I used Ac Delco, Dexron VI (6).Thanks for the writeup! What fluid did you go with?
Your very welcome, say tuned for my differential fluid change :tongue2:awesome write up for sure. Thank you very much
lol if you managed to do the tranny the diff shouldd bee a breeze for you buddyYour very welcome, say tuned for my differential fluid change :tongue2:
yea for sure, I'm curious to see if I would notice a huge difference in performance like I did when I did the tranny fluid change.lol if you managed to do the tranny the diff shouldd bee a breeze for you buddy
How would I know if I have a limited slip differential? thanksyou only need a slip additive for you diff if you have the limited slip differential.. no additive is needed for the tranny, though you could put some if youd like
Thanks, I'll check that. if not the parts department at GM should know if I give them my VIN number.depends on the model you have... check your spare tire cover build code.. it should be G80 i beileve for the LSD
Hey guys, I'm gonna do the differential fluid change right now but I can't find how tight to tighten the drain and fill plugs using torque wrench specs. If someone can tell me the accurate amount in ft lb, I'd really appreciate it!!! thanks!!!
