1 - 14 of 14 Posts
2008 Cadillac CTS
Hi, I am new to this forum so bare with me if this question has been answered a few times already.
I just bought my 2008 cadillac cts and Im extremely happy with the car. The only thing I seem to be having problems is this:
When I use the automatic start to warm the car up in the morning, I cant seem to get the heat to go on while it is running. It always goes into vent mode(I think its called vent mode) so the inside of the car is never really warm.
08 CTS4 DI Hot Lava Edition PDZ AWD FE2
My 08 warms up the car as well as pre-heats the seats and defrosts the windows. Do you have your control set on automatic? Or do you override that button and control the fan speed yourself?
Owners Manual - page 2-14
2008 Cadillac CTS
I usually just control the climate controls manually. Do I need to use the Auto Function to get the Climate Control to work during automatic start?
If you set your controls manually then when you remote start your vehicle the climate control uses the settings you have set rather than automatically based on outside temperature.
CTS, 2010 awd
Nice, how'd you get the seat heaters to activate? I got the Astrostart, but it doesn't turn on the seats.
The seat heaters come on automatically based on the outside temperature if the climate control is set to auto. I don't know what the cutoff temp is that determines this however.
CTS, 2010 awd
You must have a different heating package on yours. I have to push a button on the dash to activate them, with high/medium/low settings
They go on when remote start is used but turn off when you turn the key inside the car - then if I want them on I have to press the button on the dash.
2016 XTS4, 2008 CTS4, 1996 Eldorado ETC
Also, even though the heated seats turn on when you remote start the car, and it is cold enough, the display for it does not turn on but your tush will tell you it is working. :thumbsup:
Also heats up the passenger seat.
But as previously posted, you have to manually turn them back on after the ignition is turned on.
I do notice that the heated seats on my '96 Eldorado do heat up faster than the ones in my '08 CTS.
CTS, 2010 awd
Nope, just tried it again this past week when the temps were in the single digits. I let it run for about 10 minutes, and the seats were no warmer than the rest of the vehicle. One I got in and pushed the seat-heat button, it warmed up pretty quickly.
I would have your dealer check that out as the manual for your car specifically states that the seats will pre-heat or cool if your car has remote start.
2008 CTS 4
I personally don't think the seat heaters work very well with nobody sitting on them. In the winter when I use the remote start, the seat is never that hot, but it does warm up quicker than if I don't use remote start. The display will show it's on, just without a backlight, so it's hard to see.
My guess is that the seat heaters during the remote start period are probably at the lowest heat level just to get the chill off of the seats. Don't know what temperature that would equate to but it would not be really noticeable other than the fact that the seats don't feel ice cold when you first get into the car after a few minutes of having used the remote start. Then as brothleutner mentioned, it warms up quicker.
1 - 14 of 14 Posts
